The Window keeps on loading,I've kept waiting for one hour.I'm using Ubuntu 13.04.I've used
     sudo update-software-center
But it does not work.
on running the Command: software-center
     (software-center:4276): Gtk-WARNING **: Theme parsing error: gtk-         widgets.css:202:26: 'none' is not a valid color name
     (software-center:4276): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:209:26: 'none' is not a valid color name
     (software-center:4276): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:217:26: 'none' is not a valid color name
     (software-center:4276): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:246:26: 'none' is not a valid color name
     (software-center:4276): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:253:26: 'none' is not a valid color name
     (software-center:4276): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:482:26: 'none' is not a valid color name
     (software-center:4276): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:501:26: 'none' is not a valid color name
    (software-center:4276): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:516:26: 'none' is not a valid color name
    (software-center:4276): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:529:26: 'none' is not a valid color name
    (software-center:4276): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:1162:22: 'none' is not a valid color name
    (software-center:4276): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:1167:22: 'none' is not a valid color name
    (software-center:4276): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:1212:48: Expected ')'
    (software-center:4276): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:1223:48: Expected ')'
    (software-center:4276): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:1235:48: Expected ')'
    (software-center:4276): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:1247:48: Expected ')'
    (software-center:4276): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:1429:18: Not using units is deprecated. Assuming 'px'.
    (software-center:4276): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:1437:18: Not using units is deprecated. Assuming 'px'.
    (software-center:4276): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:1465:26: not a number
    (software-center:4276): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:1474:26: not a number
    (software-center:4276): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:1490:18: Not using units is deprecated. Assuming 'px'.
    (software-center:4276): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:1535:5: '/*' in comment block
    (software-center:4276): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:1921:22: 'none' is not a valid color name
    (software-center:4276): Gtk-WARNING **: Theme parsing error: gtk-   widgets.css:1928:22: 'none' is not a valid color name
 2014-01-28 18:48:02,299 - softwarecenter.ui.gtk3.app - INFO - setting up proxy 'None'
 2014-01-28 18:48:05,005 - softwarecenter.backend.reviews - WARNING - Could not get usefulness from server, no username in config file
 2014-01-28 18:48:05,038 - softwarecenter.plugin - INFO - activating plugin '<module   'webapps_activation' from '/usr/share/software-  center/softwarecenter/plugins/webapps_activation.pyc'>'
 2014-01-28 18:48:05,057 - softwarecenter.fixme - WARNING - logs to the root logger: '('/usr/lib/python2.7/dist-packages/gi/importer.py', 51, 'find_module')'
 2014-01-28 18:48:05,057 - root - ERROR - Could not find any typelib for    LaunchpadIntegration
 2014-01-28 18:48:05,308 - softwarecenter.db.pkginfo_impl.aptcache - INFO -   aptcache.open()
Any help is appriciated. Thank you!
Terminal
  • 515
Uninstall Software Center:
sudo apt-get purge software-center
(IMPORTANT)Remember to remove the cache
sudo rm -r ~/.cache/software-center
Reinstall Software Center:
sudo apt-get install software-center
nux
  • 39,152
SOLUTION:
wow, thanks for the support. I've found the solution just now.Its beacsuse of my theme "Malys-deda". I've removed it and now it woks fine.
Terminal
  • 515
Try reinstalling it, reinstalling will do software catalog update and may fix your problem
sudo apt-get install --reinstall software-center
Software center is slow, you can try Deepin software center
http://www.noobslab.com/2013/07/deepin-software-center-version-30-and.html
kenn
  • 5,232
