In Lubuntu, if you click on the shutdown button, the one to the right on the panel; the whole window system slows down and any click you make takes more than 20 seconds to complete.
From around the web it seems like this is a problem with the drivers for AMD cards, however I can't state it as a fact.
I'm using a SAPPHIRE HD 7770.
givanse
  • 601
The root cause of the problem has not been found, but there is a solution:
Update your video card drivers.
In my case: What is the correct way to install ATI Catalyst Video Drivers (fglrx)?
Before doing any changes execute this:
fgl_glxgears
And again after you are done. This will give you some data for comparisons afterwards.
givanse
  • 601
