I generated 300mb text file, trying to edit it using sublime 3 on xubuntu 13.10 64 bit, it's so slow and crashing, I'm not a vim/vi user, what is the best editor to work with these kind of files.
I only need to search for and remove duplicated text.
There is a graphical vim - gvim - that may be more acceptable to you than the less graphical versions. I haven't tried it on large files though.
But it really comes down to personal preference. vi could do the job, but you're not comfortable using it. That's fine, but you might not like anything suggested either. So just try a few until you find one that works both for your large files and yourself.
The problem you will find is that no editor will work well if it doesn't have the system resources available to do its job. There are limitations that may stop you no matter what editor you try - for example a 32bit system will cause problems for all editors past a couple of hundred meg. A lot of the better known editors will have tricks like disabling features, increasing swap space, etc, to allow large files to be edited.
