-1
I cannot install this tablet - the instructions are all too complicated.
If anyone has time could they please write step by step instructions for someone like me who is just learning.
Thanks.
Mjarley
Okay so I have finally done it and here is how - kind of....
All of the info you need is here including links to the tarball (archive/ zip) with the drivers in it:
Instructions for installation
The problem I had was in understanding some of the terminology so here I am going to quickly explain so others will have less problems than I did - hopefully.
sudo apt-get install linux-headers-$(uname -r) # on Debian, Ubuntu, Mint
Uname in the above goes in just like that - it is not your user name or even if it is do not change it just cut and paste that into the terminal.
As far as I can see any spaces put/ not put when they should be will mess the whole thing up so make sure that if you are editing you get it all exactly as it should be - edit in a text editor then mess about with the spaces if it is not working.
tar xjvf input-wacom-.tar.bz2
You must use the version number of the driver you are using. I used input-wacom-0.20.0 so the above became:
tar xjvf input-wacom-0.20.0.tar.bz2
You have to change to the directory the tarball is in to install it with something like cd ./username (insert yours there) / desktop - check that as I cannot remember the commands exactly but it is more or less that.
sudo cp .//wacom.ko /lib/modules/uname -r/kernel/drivers/input/tablet
For the above you have to get the kernel number by typing lsb_release -a I THINK - again check that but once you have got it put it in instead of - ie. get rid of the funny brackets.
Best piece of advice - go on the Ubuntu channel in IRC chat and ask anything you don't know - people there really helped me and it was instant rather than posting and waiting for a reply.
Hope that is useful to any noobs like me out there - I certainly learnt a bit from the whole process at least I now know what a tarball is and can install the software in one.
Mjarley
