I have downloaded Mac.OSX.Mountain.Lion.v10.8.3 and I have never burned a dmg file. How to burn this operating system in a dvd?
Braiam
  • 69,112
Open a terminal (Ctrl+Alt+T) and run the following commands:
  1. Install dmg2img:
    sudo apt-get install dmg2img
  2. Browse the folder where the file is located:
    cd PATH/TO/THE/FILE
  3. Next convert the .dmg to .img:
    dmg2img NAMEOFTHEFILE.dmg NAMEOFTHEFILE.img
  4. Create a directory to mount the image:
    mkdir /media/image
  5. Run the following:
    sudo modprobe hfsplus
  6. Mount the image:
    sudo mount -t hfsplus -o loop NAMEOFTHEFILE.img
    /media/image
  7. Download Brasero:
    sudo apt-get install brasero
  8. Create the .iso with from the previously mounted .img following this guide.
  9. Open Brasero and burn the image (.iso).
This is quite simple and you should get no troubles at all. Good luck.
Minnen
  • 529
convert dmg to iso
sudo dmg2img yourdvd.dmg yourdvd.iso
install dvd writing software in terminal
sudo apt-get install wodim
list your dvd device and note it down
wodim --devices
write your iso to dvd
wodim dev=/dev/cdrw -v -data yourdvd.iso
You can convert any dmg to iso, according to this tutorial.
After that, you can handle the file like you are used to.
Lynob
  • 6,775
davidbaumann
  • 1,915
All you should need to do is:
dmg2img example.dmg example.iso
Louis
