A BLACK screen is the result of a normal Catalyst install from the Vendor with Ubuntu 13+. I have incorporated the patch into the Knary (sourceforge) https://sourceforge.net/p/knary/discussion/general/thread/2ad755b9/?limit=25#1b3c AMD installation. But here it is for those interested in manually applying.
-- Download the catalyst 13.12 into any directory. Create this file...Here is a cat command to do this...
cat > 1310patch <<EOF
989,1001c989,1004
< #if LINUX_VERSION_CODE >= KERNEL_VERSION(3,6,3)
< if (!ACPI_SUCCESS(acpi_get_table_with_size(id, 0, &hdr, &tbl_size)))
< #else
< tbl_size = 0x7fffffff;
< if (!ACPI_SUCCESS(acpi_get_table(id, 0, &hdr)))
< #endif
< return KCL_ACPI_ERROR;
< ((acpi_table_handler)handler)(hdr);
< return KCL_ACPI_OK;
> #else
> #endif
> #if LINUX_VERSION_CODE >= KERNEL_VERSION(3,9,1)
> ((acpi_tbl_table_handler)handler)(hdr);
> #else
> #endif
> return KCL_ACPI_OK;
EOF
-- Run this Code which will backup, then patch the cat module as shown...
sudo apt-get install dpkg-dev debhelper dh-modaliases execstack dkms
sudo chmod a+x amd-catalyst-13.12-linux-x86.x86_64.run
sudo ./amd-catalyst-13.12-linux-x86.x86_64.run --extract 1310patch
MYsave=date +%B%d%Y%H%M%S
sudo cp 1310patch/common/lib/modules/fglrx/build_mod/kcl_acpi.c 1310patch/common /lib/modules/fglrx/build_mod/kcl_acpi.c.${MYsave}
sudo patch -i ./1310patch 1310patch/common/lib/modules/fglrx/build_mod/kcl_acpi.c
cd 1310patch
sudo./ati-installer.sh 13.251 --buildpkg Ubuntu/saucy
-- now install the packages as the compiled correctly
-- install the resulting packages in order is best
sudo dpkg -i fglrx_
sudo dpkg -i fglrx-dev
sudo dpkg -i fglrx-a*
-- catch all
sudo dpkg -i *.deb
FORCE Uninstall
BLACK screen --
Ctrl+Alt+F1 ...Login...
sudo /usr/share/ati/amd-uninstall.sh --force
sudo /usr/share/ati/fglrx-uninstall.sh --force
sudo reboot
Viola!
