I recently installed Ubuntu 12.04.4 LTS with Xfce 4.10 on my Asus F5RL AP033C laptop. When I open nm-connection-editor from the notifications area (on it the Enable Wireless is in grey), in the Wireless tab there are no networks, same with Wicd Network Manager. The WiFi LED on the laptop stays on all the time and I can't control it neither from Wicd nor by pressing Fn+F2.
Firstly, I searched the Asus site for drivers, but there were no Linux ones.
I tried adding to /etc/rc.local the line:
echo 1 | tee /sys/devices/platform/asus_laptop/wlan
because of these topics I've found on Ubuntu Forums:
One strange thing about those is that I changed the line I was adding from asus-laptop to asus_laptop, because of the already existing folder. That wlan file contained 1 in it, so I edited it to become 0 and the LED turned off. I switched it back on, but I still couldn't see the list of available networks.
I've also tried:
sudo apt-get purge --remove bcmwl-kernel-source
sudo apt-get install linux-firmware-nonfree
sudo modprobe b43
as suggested in (Asus F5RL - wifi cannot connect), but without any effect. When I was searching the net for my laptop characteristics, I've found that my wireless is Integrated 802.11b/g.
sudo iwlist scanning returns:
wlan0     Interface doesn't support scanning : Network is down
lo        Interface doesn't support scanning.
eth0      Interface doesn't support scanning.
But there's an exception - when I first boot my laptop after being shut down it returns:
wlan0     No scan results
sudo lshw -C network returns:
  *-network DISABLED
       description: Wireless interface
       product: AR242x / AR542x Wireless Network Adapter (PCI-Express)
       vendor: Qualcomm Atheros
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: wlan0
       version: 01
       serial: 00:15:af:6f:2f:ad
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=ath5k driverversion=3.8.0-35-generic firmware=N/A latency=0 link=no multicast=yes wireless=IEEE 802.11bg
       resources: irq:16 memory:fa9f0000-fa9fffff
  *-network
       description: Ethernet interface
       product: Attansic L2 Fast Ethernet
       physical id: 0
       bus info: pci@0000:06:00.0
       logical name: eth0
       version: a0
       serial: 00:1e:8c:73:14:d3
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress vpd bus_master cap_list rom ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=atl2 driverversion=2.2.3 duplex=full firmware=L2 ip=192.168.55.98 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
       resources: irq:40 memory:feac0000-feafffff memory:feaa0000-feabffff
Except when I just start my laptop, when it returns:
  *-network
       physical id: 0
       logical name: wlan0
       version: 01
       width: 64 bits
       clock: 33MHz
  *-network
       physical id: 0
       logical name: eth0
       version: a0
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
lsusb returns:
Bus 001 Device 003: ID 0bda:0116 Realtek Semiconductor Corp. Mass Storage Device
Bus 001 Device 004: ID 174f:6a31 Syntek Web Cam - Asus A8J, F3S, F5R, VX2S, V1S
Bus 002 Device 002: ID 046d:c05b Logitech, Inc. M-U0004 810-001317 [B110 Optical USB Mouse]
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
uname -a returns:
Linux qxp-F5RL 3.8.0-35-generic #50~precise1-Ubuntu SMP Wed Dec 4 17:28:45 UTC 2013 i686 i686 i386 GNU/Linux
dmesg | grep found returns:
[    0.000000] found SMP MP-table at [mem 0x000ff780-0x000ff78f] mapped at [c00ff780]
[    0.120335] ACPI: No dock devices found.
[    0.148019] pnp: PnP ACPI: found 10 devices
[    1.180113] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.180297] hub 1-0:1.0: USB hub found
[    1.240054] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    1.240210] hub 2-0:1.0: USB hub found
[    1.300053] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    1.300198] hub 3-0:1.0: USB hub found
[    1.360050] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    1.360195] hub 4-0:1.0: USB hub found
[    1.420053] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    1.420204] hub 5-0:1.0: USB hub found
[    1.480054] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    1.480202] hub 6-0:1.0: USB hub found
[    1.515808] isapnp: No Plug & Play device found
[    1.518825] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[    1.700752] usb 1-4: New USB device found, idVendor=0bda, idProduct=0116
[    2.205672] usb 1-7: New USB device found, idVendor=174f, idProduct=6a31
[    2.639094] usb 2-1: New USB device found, idVendor=046d, idProduct=c05b
[   10.278986] lp: driver loaded but no devices found
[   13.667622] ath5k: phy0: Atheros AR2425 chip found (MAC: 0xe2, PHY: 0x70)
dmesg | grep -i firmware returns nothing.
iwconfig returns:
wlan0     IEEE 802.11bg  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=off
          Retry  long limit:7   RTS thr:off   Fragment thr:off
          Power Management:off
lo        no wireless extensions.
eth0      no wireless extensions.
sudo lspci -nn has:
02:00.0 Ethernet controller [0200]: Qualcomm Atheros AR242x / AR542x Wireless Network Adapter (PCI-Express) [168c:001c] (rev 01)
/var/log/udev has:
UDEV  [13.860291] add      /devices/pci0000:00/0000:00:04.0/0000:02:00.0/net/wlan0 (net)
ACTION=add
DEVPATH=/devices/pci0000:00/0000:00:04.0/0000:02:00.0/net/wlan0
DEVTYPE=wlan
ID_BUS=pci
ID_MM_CANDIDATE=1
ID_MODEL_FROM_DATABASE=AR242x / AR542x Wireless Network Adapter (PCI-Express)
ID_MODEL_ID=/sys/devices/pci0000:00/0000:00:04.0/0000:02:00.0
ID_VENDOR_FROM_DATABASE=Qualcomm Atheros
ID_VENDOR_ID=0x168c
IFINDEX=3
INTERFACE=wlan0
SEQNUM=1871
SUBSYSTEM=net
UDEV_LOG=3
USEC_INITIALIZED=13860052
It might have something to do with the result of sudo rfkill list all, which changes depending on whether I unplug the ethernet cable or whether I press Fn+F2. I explained exactly how in my comments on Olli's answer.
Zanna
  • 72,312
qxp
  • 91
I had same/similar problem with my computer, and after enabling wlan from /sys (setting wlan file contents to 1), solution appeared to be really trivial:
ifconfig wlan0 up
iwlist wlan0 scanning
Apparently iwlist returns Interface doesn't support scanning : Network is down if device is marked as down, even though device supports scanning.
Olli
  • 9,129
If your Wireless is hard blocked try to enable it in BIOS
On first boot screen enter BIOS hit (F2 or F10 or F12 - depending on your BIOS configuration)
When in BIOS search for wireless to enable it if disabled (Most likely under configuration -> wireless -> enabled)
When enabled confirm and boot normally (probably F10)
Hope it helps.
This command bellow in your case wont do much since you run on atheros and not broadcom driver, so not really solving any issue in your case.
sudo modprobe b43
UPDATE Some Atheros drivers have issues with hardware encryption or decryption. Try this command bellow as root user
echo "options ath5k nohwcrypt=1" > /etc/modprobe.d/ath5k.conf
Reboot, see if finally works.
danijelc
  • 898
