I have 2 notebook that see all the wireless access point except one.
The computers are:
- HP Pavilion DV6 - wifi Broadcom BCM4312 - Kubuntu 13.10 64bit
- Asus EEEPC 1018P - wifi broadcom BMC4313 - Kubuntu 14.04 64 Bit Aplha 2
The missing access point is a D-Link DIR-615 set up with:
- mixed mode "Mixed 802.11n, 802.11g and 802.11b"
- auto channel scan enabled
- wireless channel CH13 (not changeable)
I have another AP and this one (a TP-Link) is correctly identified and used for connections.
All other devices I have in home (some Android smartphones and tablets, an iPad and a Playstation) correctly see and use the missing AP
Also the computers connets to this AP if booted with Windows.
I don't know in which Kubuntu version or update the problem arose, but I tried on the Asus a fresh install of 12.04.3, 12.10, 13.04, 13.10, 14.04Alpha2 and obtained the same result:
The driver in use is WL.
nm-tool on HP says
Device: eth1 [efm2] ---------------------------------------------------------
Type: 802.11 WiFi
Driver: wl
State: connected
Default: yes
HW Address: F0:7B:CB:95:14:08
Capabilities:
Speed: 54 Mb/s
Wireless Properties
WEP Encryption: yes
WPA Encryption: yes
WPA2 Encryption: yes
Wireless Access Points (* = current AP)
Telecom-64869841:Infra, A4:B1:E9:D3:B6:D1, Freq 2437 MHz, Rate 54 Mb/s, Strength 10 WPA WPA2
BOX: Infra, A0:F3:C1:98:58:80, Freq 2447 MHz, Rate 54 Mb/s, Strength 17 WPA2
FASTWEB-1-c85NyZctS6gd: Infra, E0:91:53:4E:4C:58, Freq 2437 MHz, Rate 54 Mb/s, Strength 12 WPA
*efm2: Infra, F8:1A:67:30:A0:08, Freq 2412 MHz, Rate 54 Mb/s, Strength 66 WPA >WPA2
IPv4 Settings:
Address: 192.168.253.100
Prefix: 24 (255.255.255.0)
Gateway: 192.168.253.1
DNS: 192.168.253.1
My AP are efm2 (listed) and efm (missing); all other AP are from neighbors
Followed the instructions in the first response.
I still see only the far AP and don't see the nearest DIR-615 AP.
nm-tool says:
- Device: wlan0 ----------------------------------------------------------------
Type: 802.11 WiFi
Driver: b43
State: disconnected
Default: no
Capabilities:
Wireless Properties
WEP Encryption: yes
WPA Encryption: yes
efm2: Infra, F8:1A:67:30:A0:08, Freq 2412 MHz, Rate 54 Mb/s, Strength 46 WPA >WPA2
What else can I try?
As in the comments, the iwlist command is
mirto@msb03:/etc/network$ sudo iwlist eth1 freq
eth1 26 channels in total; available frequencies :
Channel 01 : 2.412 GHz
Channel 02 : 2.417 GHz
Channel 03 : 2.422 GHz
Channel 04 : 2.427 GHz
Channel 05 : 2.432 GHz
Channel 06 : 2.437 GHz
Channel 07 : 2.442 GHz
Channel 08 : 2.447 GHz
Channel 09 : 2.452 GHz
Channel 10 : 2.457 GHz
Channel 11 : 2.462 GHz
Channel 12 : 2.467 GHz
Channel 13 : 2.472 GHz
Channel 14 : 2.484 GHz
Channel 36 : 5.18 GHz
Channel 38 : 5.19 GHz
Channel 40 : 5.2 GHz
Channel 42 : 5.21 GHz
Channel 44 : 5.22 GHz
Channel 46 : 5.23 GHz
Channel 48 : 5.24 GHz
Channel 149 : 5.745 GHz
Channel 153 : 5.765 GHz
Channel 157 : 5.785 GHz
Channel 161 : 5.805 GHz
Channel 165 : 5.825 GHz
At this point, I returned to the wl driver because I see no difference in behaviour
Following bug [wireless-tools] Cannot use channel 12 or 13 of wifi in a region where it is legal
I tried
mirto@msb03:/etc/network$ sudo cat /sys/module/cfg80211/parameters/ieee80211_regdom
00
That says 00 instead of US or EU
After googling bugs I found that there exist an /etc/defeult/crda file with an empty domain
ASAP I'll try to set the domain
sudo cat /etc/default/crda
Set REGDOMAIN to a ISO/IEC 3166-1 alpha2 country code so that iw(8) may set
the initial regulatory domain setting for IEEE 802.11 devices which operate
on this system.
Governments assert the right to regulate usage of radio spectrum within
their respective territories so make sure you select a ISO/IEC 3166-1 alpha2
country code suitable for your location or you may infringe on local
legislature. See `/usr/share/zoneinfo/zone.tab' for a table of timezone
descriptions containing ISO/IEC 3166-1 alpha2 country codes.
REGDOMAIN=
so I tried
REGDOMAIN=IT
but nothing changed
After setting IT in domain. I have:
$ sudo iw reg get
country IT:
(2402 - 2482 @ 40), (N/A, 20)
(5170 - 5250 @ 40), (N/A, 20)
(5250 - 5330 @ 40), (N/A, 20), DFS
(5490 - 5710 @ 40), (N/A, 27), DFS
(57240 - 65880 @ 2160), (N/A, 40), NO-OUTDOOR
I tried on another computer to scan the missing AP:
- Abandoned again the
wldriver for theb43driver - rebooted
- added the IT domain in
/etc/default/crda
Now seems to work.
I'll try the same operation on the Asus that have a fresh install
_________ Solved on Asus ___________________________
Operations to solve the problem on Asus Kubuntu 14.04Alpha2
sudo apt-get remove --purge bcmwl-kernel-source sudo apt-get install linux-firmware-nonfree
reboot
reboot
add IT as domain in /etc/default/crda
REGDOMAIN=IT
reboot
reboot
______ last update _________________________
The drivers selected are:
on HP driver b43
on Asus driver brcmsmac
