I have an Apple Magic Mouse, and it's almost unusable since the sensitivity is too high. Yet in the Mouse/Touchpad settings, the pointer speed is set to the slowest possible setting. Is there a way to manually change this setting so that it's much slower than the slowest setting?
Asked
Active
Viewed 1.8k times
22
The easiest way of doing this is xset m. The general format is:
xset m ACCELERATION THRESHOLD
where ACCELERATION defines how many times faster the cursor will move than the default speed, when the cursor moves more than THRESHOLD pixels in a short time. ACCELERATION can be a fraction, so if you want to slow down the mouse you can use 1/2, and if 3 is slightly too fast, but 2 is too slow, you can use 5/2, etc.
For example:
xset m 1/2 4
To get the current values, use:
xset q | grep -A 1 Pointer
For more information, see here.
terdon
- 104,119
