I was running an apt-get upgrade (not version upgrade, just normal), when I got this message:
You might want to run 'apt-get -f install' to correct these.
The following packages have unmet dependencies: icedtea-7-jre-jamvm : Depends: openjdk-7-jre-headless (= 7u51-2.4.4-0ubuntu0.13.10.1)
openjdk-7-jre : Depends: openjdk-7-jre-headless (= 7u51-2.4.4-0ubuntu0.13.10.1)
openjdk-7-jre-lib : Breaks: openjdk-7-jre-headless (< 7u45-2.4.3-1)
E: Unmet dependencies. Try using -f.
I then run as recommended "apt-get install -f" and here is the output:
Preparing to replace openjdk-7-jre-headless:amd64 7u25-2.3.12-4ubuntu3 (using .../openjdk-7-jre-headless_7u51-2.4.4-0ubuntu0.13.10.1_amd64.deb) ...
Unpacking replacement openjdk-7-jre-headless:amd64 ... dpkg: error processing /var/cache/apt/archives/openjdk-7-jre-headless_7u51-2.4.4-0ubuntu0.13.10.1_amd64.deb (--unpack):
trying to overwrite shared '/etc/java-7-openjdk/sound.properties', which is different from other instances of package openjdk-7-jre-headless:amd64
Errors were encountered while processing: /var/cache/apt/archives/openjdk-7-jre-headless_7u51-2.4.4-0ubuntu0.13.10.1_amd64.deb
How can I fix this error? Thanks
UPDATE:
The 1st time, I ran the command, there was no output. Now, running it again, I get:
dpkg: dependency problems prevent removal of
openjdk-7-jre-headless:amd64: icedtea-7-jre-jamvm:amd64 depends on
openjdk-7-jre-headless (= 7u51-2.4.4-0ubuntu0.13.10.1).
dpkg: error processing openjdk-7-jre-headless:amd64 (--remove):
dependency problems - not removing Errors were encountered while
processing: openjdk-7-jre-headless:amd64
duduklein
  • 131
Try to remove previously installed openjdk-7-jre-headless:amd64 package,
sudo dpkg -r openjdk-7-jre-headless:amd64
Then try,
sudo apt-get -f install
Avinash Raj
  • 80,446
