10
I have been using Ubuntu for a short period of time. I have seen the term "bash" in many places, including a terminal. I have still not understood what it is.
Can somebody please explain clearly?
muru
  • 207,228
CENTAUR
  • 3,409
Expansion for Bash is Bourne Again shell.
Bash is the shell, or command language interpreter, for the GNU operating system. The name is an acronym for the ‘Bourne-Again SHell’, a pun on Stephen Bourne, the author of the direct ancestor of the current Unix shell sh, which appeared in the Seventh Edition Bell Labs Research version of Unix.
Bash is largely compatible with sh and incorporates useful features from the Korn shell ksh and the C shell csh. It is intended to be a conformant implementation of the IEEE POSIX Shell and Tools portion of the IEEE POSIX specification (IEEE Standard 1003.1). It offers functional improvements over sh for both interactive and programming use.
While the GNU operating system provides other shells, including a version of csh, Bash is the default shell. Like other GNU software, Bash is quite portable. It currently runs on nearly every version of Unix and a few other operating systems - independently-supported ports exist for MS-DOS, OS/2, and Windows platforms.
Source
Eliah Kagan
  • 119,640
Avinash Raj
  • 80,446
Bash is a command processor, typically run in a text window, allowing the user to type commands which cause actions. Bash can also read commands from a file, called a script. Like all Unix shells, it supports filename wildcarding, piping, here documents, command substitution, variables and control structures for condition-testing and iteration. The keywords, syntax and other basic features of the language were all copied from sh. Other features, e.g., history, were copied from csh and ksh. Bash is a POSIX shell but with a number of extensions.
The name itself is an acronym, a pun and descriptive. As an acronym, it stands for Bourne-again shell, referring to its objective as a free replacement for the Bourne shell. As a pun, it expressed that objective in a phrase that sounds the same as born again, a term for spiritual rebirth. The name is also descriptive of what it did, bashing together the features of sh, csh and ksh.
