I just made 120 GB of unallocated space from my Windows 8 partition to put into my already existing Ubuntu home (sda7) partition.
The problem is when I try to create new partition from unallocated it says
It is not possible to create more than 4 primary partitions
All I want to do is put that free space into my Ubuntu (to sda7).
sda2 - Windows 8 drive C
sda3 - Windows 8 drive D
Edit: So I run "Try Ubuntu", unmounted all partitions, and resized /dev/sda4 so unallocated space is not below sda4. But when I try to resize /dev/sda7 (which I want) it only allows me to resize for 7Gb or so, not all 120Gb I need.
user1880405
  • 866
  • 14
  • 28
Seems to be the limit due to upgrade from windows to ubuntu-- where you already used up 4 primary partitions - only remedy is to backup data - re-install and this time use gparted to create required no of partitions/types.
I faced the same problem -- I used the same D: /E: drive from windows 10 installation - but formatted C: drive for ubuntu.
To put that 120 GB free space into Ubuntu ( /dev/sda7) partition,follow the below steps.
  • First you had to boot Ubuntu live disk.
  • Click on "try ubuntu" option on startup and then open gparted from Dash.Make sure that all your partitions are unmounted.
  • Right-click on the /dev/sda4 partition and then choose Resize/Move option to increase its size with the 120 GB unallocated space by dragging the left arrow to the extreme left.After resizing,apply the changes.
  • Now your 120 GB unallocated space will comes inside extended partition and just below to the /dev/sda7 partition.
  • Right-click on the /dev/sda7 partition and select Resize/Move option,now you can be able to add 120 GB unallocated space to your ext4 partition by dragging the right arrow to the extreme right.
Avinash Raj
  • 80,446
