After using command apt-get upgrade:
After this operation, 80.9 kB of additional disk space will be used.
Do you want to continue [Y/n]? y
Extracting templates from packages: 100%
Preconfiguring packages ...
dpkg: unrecoverable fatal error, aborting:
 syntax error: unknown group 'crontab' in statoverride file
E: Sub-process /usr/bin/dpkg returned an error code (2)
after removing empathy and access prompt "for passwords and secrets" from the interface software updater not available on the sidebar or via search
Running 12.10.
kiri
  • 28,986
Amy
Try to use statoverride-old file ,
sudo mv /var/lib/dpkg/statoverride /var/lib/dpkg/statoverride.bad
sudo cp /var/lib/dpkg/statoverride-old /var/lib/dpkg/statoverride
sudo apt-get update
sudo apt-get upgrade
Avinash Raj
  • 80,446
