I attempted to update wine from my existing 1.5 by installing 1.7 through apt-get but apparently it only partially succeeded. Now it looks like I'm trapped in a catch-22: When I try to install 1.7 it fails because 1.5 is already installed and is using some of the same files. I apparently can't remove either 1.5 or the installed portion of 1.7 because of the unmet dependency.
Running apt-get -f install makes it try to install wine1.7-i386 but this fails:
Unpacking wine1.7-i386:i386 (from .../wine1.7-i386_1%3a1.7.11-0ubuntu1_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/wine1.7-i386_1%3a1.7.11-0ubuntu1_i386.deb (--unpack):
 trying to overwrite '/usr/bin/wine', which is also in package wine1.5 1.5.5-0ubuntu1~ppa1~oneiric1+pulse17
Running apt-get autoclean after that removes wine1.7-i386 but either way I can't seem to get beyond that. Also, Ubuntu Update Manager crashes on load, obviously due to the same error.
Any advice will be appreciated. Thanks.
kiri
  • 28,986
Remove wine1.5
sudo apt-get remove wine1.5
Then install wine1.7
sudo apt-get remove wine1.7
user.dz
  • 49,176
