The emblems in Nautilus don't quite fit my needs. How can I add a new one, just for my user account?
Asked
Active
Viewed 1,955 times
You can also set a custom emblem on a file from a script by running this command:
gvfs-set-attribute -t string <filename> metadata::custom-icon file:///home/user/path/to/icon.png
Tolli
- 502
The previous answer really create a custom icon for the object, which is not exactly the same thing an emblem is.
The first answer unfortunately does not work anymore for gnome3. I found that, to create an emblem named for example "mymusic", you can add a png 48x48 image called emblem-mymusic.pngin the directory:
~/.icons/hicolor/48x48/emblems
and in the same directory you create a text file, called emblem-mymusic.icon with the content:
[Icon Data]
DisplayName=mymusic
That's it. Now you can set/unset them following the answer to Is there any tweak to bring back emblems in Nautilus?
