I try to install php5-fpm package but I have this information:
php5-fpm : Depends: php5-common (= 5.5.7+dfsg-1+sury.org~quantal+1) but 5.3.10-1ubuntu3 is to be installed
Here is full terminal output:
root@myserv /home/pw # sudo apt-get install php5-common
Reading package lists... Done
Building dependency tree
php5-common is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 43 not upgraded.
and:
root@myserv /home/pw # sudo apt-get install php5-fpm --fix-missing --fix-broken
How to fix it?
