-1
After i upgrade to PHP5.5 like in this thread
How do I install different (upgrade or downgrade) PHP version in still supported Ubuntu release?
my phpmyadmin is not working after i try to access to over my apache2 webinterface.
ERROR 404 PAGE NOT FOUND
has anyone a solution for this Problem?
remove and try to install it new was no success
The Masta
  • 127
If you have installed phpmyadmin with apt - reconfigure it from terminal:
sudo dpkg-reconfigure phpmyadmin
See more at http://ubuntuforums.org/showthread.php?t=812971
If necessary - check out for existing config at /etc/apache2/conf-enabled - there should be phpmyadmin.conf symlink.
or
you can install it manually - from http://www.phpmyadmin.net - download and unpack in web root directory. If you already tried to install phpmuadmin with apt - avoid using phpmyadmin as directory name, use padmin, for example. Then point to yoursite.net/padmin.
ulcha
  • 464
