26
I typed cd - in terminal by mistake today, and I got an error saying:
bash: cd: OLDPWD not set
And unfortunately, man cd doesn't exist.
No manual entry for cd
What does it actually do?
Dan
  • 14,180
cd - switches between the old and new present working directories.
avinash@avinash:~$ cd -
avinash@avinash:~$ cd ~/Desktop
avinash@avinash:~/Desktop$ pwd
/home/avinash/Desktop
avinash@avinash:~/Desktop$ cd -
/home/avinash
avinash@avinash:~$
See also,
avinash@avinash:~$ echo $OLDPWD
avinash@avinash:~$ cd ~/Desktop avinash@avinash:~/Desktop$ echo $OLDPWD /home/avinash avinash@avinash:~/Desktop$ cd d avinash@avinash:~/Desktop/d$ echo $OLDPWD /home/avinash/Desktop avinash@avinash:~/Desktop/d$
The $OLDPWD variable stores the path of the previous present working directory.
Dan
  • 14,180
Avinash Raj
  • 80,446
10
Avinash Raj's answer is completely correct but as for the manual entry, you can get the POSIX manual pages and then man cd will work:
sudo apt-get install manpages-posix
man cd
The bit that tells you all this is the OPERANDS section:
-      When a hyphen is used as the operand, this shall be equivalent to the command:
       cd "$OLDPWD" && pwd
which changes to the previous working directory and then writes its name.
Oli
  • 299,380
