The termial say's package google-chrome-stable needs to be reinstalled but can't find it in the archives. What do I need to do? I keep getting errors.
Asked
Active
Viewed 1.9k times
AzkerM
- 10,390
To uninstall previously install one:
sudo apt-get remove google-chrome-stable
For 32 bit OS:
cd /tmp && wget -c https://dl.google.com/linux/direct/google-chrome-stable_current_i386.deb
sudo dpkg -i google-chrome-stable_current_i386.deb
sudo apt-get -f install
For x64 OS:
cd /tmp && wget -c https://dl.google.com/linux/direct/google-chrome-stable_current_amd64.deb
sudo dpkg -i google-chrome-stable_current_amd64.deb
This stuff has the same or almost the same procedure.
run an update
sudo apt-get updatedownload the Debian file
wget -c https://dl.google.com/linux/direct/google-chrome-stable_current_i386.debinstall the file using dpkg manager.
sudo dpkg -i google-chrome-stable_current_i386.deb sudo apt-get -f install
That should have you fixed with everything needed for Google Chrome installation on Ubuntu.
David Foerster
- 36,890
- 56
- 97
- 151
Zuko
- 1,277
Try below;
Open a terminal (press CTRL+ALT+T) and type the following wget command to grab .deb file:
FOR 32bit
wget https://dl.google.com/linux/direct/google-chrome-stable_current_i386.deb
or if you've already downloaded the deb file, navigate to the directory using cd & type the following command;
Errors will display on screen. To fix it, run below;
AzkerM
- 10,390
