I need some help about permission. I had a permission drwxrwxr-x but I try to change the permission with chmod 755 /folder/ and after that I receive permission drwxr-xr-x but I would like to change it back to drwxrwxr-x. Please can you help me with this? Filip
For drwxrwxr-x it's:
chmod 775 the_path_to_target
For drwxr-xr-x it's:
chmod 755 the_path_to_target
- 16,917
allways remember the following
r - read
w - write
x - execute
and permission matrix is
7 = all rights
6 = read and write
5 = read and execute
4 = read only
3 = execute and write
2 = write only
1 = execute only
0 = no rights
i think this will help you to understand the permission and by adding + you give the permission and - you remove the permission
- 526
remembering the letter form is easier than the numbers (in my opinion) for example:
chmod a+w file
the part before the sign
the user who owns it (u), other users in the file's group (g), other users not in the file's group (o), or all users (a)
the sign
The operator + causes the selected file mode bits to be added to the existing file mode bits of each file; - causes them to be removed; and = causes them to be added and causes unmentioned bits to be removed except that a directory's unmentioned set user and group ID bits are not affected.
the last part
read (r), write (w), execute (or search for directories) (x)
you can run
chmod a+rx file
chmod ug+w file
- 171
