I am getting a problem in Ubuntu as an error opening the cache, the list of software sources could not be read in my /etc/apt/sources.list file and the package lists or status file could not be parsed or opened. I am new to Ubuntu, so I could not determine what is causing the problem. I also have a problem opening the Ubuntu Software Center and once I commented out line no. 56 stating deb http://archive.canonical.com/raring partner, Ubuntu Software Center opens OK. What could the problem be? I am including 4 lines from my sources.list file.
Source.list code on my line 56 is this:
# deb-src http://archive.canonical.com/raring partner
Terminal output:
Traceback (most recent call last):
File "/usr/lib/python2.7/dist-packages/gi/overrides/GLib.py", line 629, in <lambda>
return (lambda data: callback(*data), user_data)
File "/usr/share/software-center/softwarecenter/db/pkginfo_impl/aptcache.py", line   261, in open
self._cache = apt.Cache(progress)
File "/usr/lib/python2.7/dist-packages/apt/cache.py", line 105, in __init__
self.open(progress)
File "/usr/lib/python2.7/dist-packages/apt/cache.py", line 150, in open
self._cache = apt_pkg.Cache(progress)
SystemError: E:Malformed line 56 in source list /etc/apt/sources.list (dist parse),       E:The list of sources could not be read., E:The package lists or status file could not be parsed or opened.
2014-01-22 11:27:29,685 - softwarecenter.db.pkginfo_impl.aptcache - INFO - aptcache.open()
karel
  • 122,292
  • 133
  • 301
  • 332
minu
Since you made changes to the sources, you should update the apt so that the changes are recognized.
To do that, open a terminal (press Ctrl + Alt + T) and enter the command:
sudo apt-get update
and you should be done.
rusty
  • 16,917
