10
On an Asus H87-PRO:
$ sudo pwmconfig
# pwmconfig revision 5857 (2010-08-22)
/usr/sbin/pwmconfig: There are no pwm-capable sensor modules installed
here's the output from $ sensors:
acpitz-virtual-0
Adapter: Virtual device
temp1:        +27.8°C  (crit = +97.0°C)
temp2:        +29.8°C  (crit = +97.0°C)
coretemp-isa-0000
Adapter: ISA adapter
Physical id 0:  +40.0°C  (high = +86.0°C, crit = +92.0°C)
Core 0:         +32.0°C  (high = +86.0°C, crit = +92.0°C)
Core 1:         +33.0°C  (high = +86.0°C, crit = +92.0°C)
Core 2:         +40.0°C  (high = +86.0°C, crit = +92.0°C)
Core 3:         +31.0°C  (high = +86.0°C, crit = +92.0°C)
pkg-temp-0-virtual-0
temp1:        +41.0°C
do I need/should I try https://github.com/ambrosa/Asus-P8P67-Ubuntu-lm-sensors-driver ?
do I need some acpi_osi=... (Linux?) or acpi_enforce_resources=... (lax?) boot option?
do I need to install sensord read-edid i2c-tools on this board?
do I need to do something in the BIOS to "allow" fan control by the OS?
vorburger
  • 704
Can you post the output of sudo sensors-detect?
Edit: Nevermind. I read the pastbin you linked (totally missed it). It looks like sensors-detect does not fully recognize your Super I/O chip. According to this the Super I/O is the Nuvoton (formerly Winbond) NCT 5538D. The chip ID appears to be the same as the NCT6775 family. You can download the driver from here, which is a link to github of the maintainer of that kernel module (it is a download link).
Then do the following:
cd /path/to/directory/you/saved/the/file
tar xzvf master.tar.gz
sudo make
sudo make install
modprobe hwmon
modprobe nct6775
Then, check to make sure you did everything correctly:
lsmod | grep nct
The output should look something like [this][3]:
user@computer:/# lsmod | grep nct
nct6775                44104  0
hwmon_vid              12388  1 nct6775
Then run sudo pwmconfig and hopefully everything should be ok.
Tim
  • 33,500
ChrisR.
  • 527
You need to add acpi_enforce_resources=lax to the kernel command line, and to modprobe the module that sudo sensors-detect says to ( and iirc, offers to add to /etc/modules for you ).
psusi
  • 38,031
