I am trying to install OpenCPN, a navigation and chart program. The install guide recommend this:
It is also possible to install the package via dpkg or rpm, on the condition that all dependencies are met.To make sure that this is the case on Ubuntu, open a terminal window to get a command line, (Applications->Accessories->Terminal) and copy and paste the following line:
sudo apt-get install libwxgtk2.8-0 libwxbase2.8-0 wx-common libglu1-mesa libgl1-mesa-glx zlib1g bzip2 gpsd gpsd-clients xcalib libportaudio2. Then proceed with the commands below.
I typed:
in the terminal and got this:
Reading package lists... Done Building dependency tree Reading state information... Done bzip2 is already the newest version. libportaudio2 is already the newest version. libportaudio2 set to manually installed. zlib1g is already the newest version. xcalib is already the newest version. libglu1-mesa is already the newest version. Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help resolve the situation: The following packages have unmet dependencies: libgl1-mesa-glx : Depends: libglapi-mesa (= 8.0.4-0ubuntu0.7) Recommends: libgl1-mesa-dri (>= 7.2) E: Unable to correct problems, you have held broken packages.
What should I do now to fix the problem with libgl1-mesa-glx?
