I have been trying to install the ubuntu developer environment so that I may begin gaining practice in app development. But once I try to install ubuntu-sdk I get the following error:
ubuntu-sdk : Depends: ubuntu-html5-container but it is not going to be installed
for which I then proceed to insert the command:
sudo apt-get install ubuntu-html5-container
in which I then receive the following error message:
ubuntu-html5-container : Depends: qtdeclarative5-ubuntu-ui-extras-browser-plugin but it is not installable
at which point I would feel logical to insert the command:
sudo apt-get install qtdeclarative5-ubuntu-ui-extras-browser-plugin
and my new error message is:
Package qtdeclarative5-ubuntu-ui-extras-browser-plugin is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or is only available from another source
I have no idea what I'm doing wrong and I have updated my repository libraries several times and still nothing. Could someone please tell me what it is that I'm doing wrong? Why isn't this working like it should?
I have the very same issue trying to install ubuntu-sdk on a new VM today The VM is running Ubuntu 12.04 LTS 64bit
Here how I solved the issue:
  • downloaded the packages:
qtdeclarative5-ubuntu-ui-extras-browser-plugin-assets
  • installed manually the packages dependencies:
sudo apt-get install libqt5core5
sudo apt-get install libqt5gui5
sudo apt-get install libqt5qml5
sudo apt-get install libqt5quick5 libqt5sql5 libqt5webkit5 libqt5sql5-sqlite
sudo apt-get install libqt5webkit5-qmlwebkitplugin qtdeclarative5-qtquick2-plugin
sudo dpkg -i qtdeclarative5-ubuntu-ui-extras-browser-plugin-assets_0.22+13.10.20131011.1-0ubuntu1_all.deb
sudo apt-get install qtdeclarative5-ubuntu-ui-toolkit-plugin
sudo apt-get install qtdeclarative5-unity-action-plugin
sudo apt-get install qtdeclarative5-window-plugin
sudo dpkg -i qtdeclarative5-ubuntu-ui-extras-browser-plugin_0.22+13.10.20131011.1-0ubuntu1_amd64.deb
Finally run the command to install the skd:
sudo apt-get install ubuntu-sdk
That worked fine for me :)
sergico
  • 203
Try only this command on terminal,
sudo apt-get install aptitude; sudo aptitude install ubuntu-sdk
Avinash Raj
  • 80,446
