I am using ubuntu 13.04. Initially I had installed apache2 and it was working fine but later it started giving some issues so i removed apache using following commands
sudo apt-get autoremove
sudo apt-get remove apache2*
dpkg -S which apache2
and then i reinstalled apache2 using
sudo apt-get install apache2
Installation was almost done but then i got following message
  • Starting web server apache2
    Syntax error on line 6 of /etc/apache2/sites-enabled/ssl: SSLCertificateFile: file '/etc/apache2/ssl/apache.pem' does not exist or is empty Action 'start' failed. The Apache error log may have more information.
    [fail]
    invoke-rc.d: initscript apache2, action "start" failed. Setting up apache2 (2.2.22-6ubuntu5.1) ...
output to ls /etc/apache2/sites-enabled/ is default-ssl mysite ssl
content of mysite is
ServerAdmin webmaster@localhost</p>
DocumentRoot /home/gautam/apache/
<Directory />
    Options FollowSymLinks
    AllowOverride None
</Directory>
<Directory /home/gautam/apache/>
    Options Indexes FollowSymLinks MultiViews
    AllowOverride None
    Order allow,deny
    allow from all
</Directory>
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
    AllowOverride None
    Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
    Order allow,deny
    Allow from all
</Directory>
ErrorLog ${APACHE_LOG_DIR}/error.log
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
CustomLog ${APACHE_LOG_DIR}/access.log combined
after running sudo rm /etc/apache2/sites-enabled/*ssl i am getting the following output and apache2 is OFF
* Restarting web server apache2
apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1 for ServerName
(98)Address already in use: make_sock: could not bind to address [::]:443
        [ OK ]
What to do? Any suggestions???
user.dz
  • 49,176
I had removed SSL but it was still giving following error:
Restarting web server apache2 apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1 for ServerName apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1 for ServerName (98)Address already in use: make_sock: could not bind to address [::]:443 [ OK ]
I googled it out and referred to these 2 posts:
Finally, I disabled the SSL using:
a2dismod ssl
