How to take the executable file of the particular software and install in other system like we tacking back up in android applications
This answer helps if you only need to move eclipse to another computer, with same OS, which is Ubuntu
There is a better generous solution in comments, given by user hash.
First of all you should find where exactly you eclipse installation folder is. Usually it is /usr/lib/eclipse. You can put it in tar sudo tar -pcvzf eclipse.tar.gz /usr/lib/eclipse, and copy to your another computer.
Then do this line by line on computer where you want to copy:
cd /usr/lib
sudo mkdir eclipse && cd eclipse
sudo tar -pxvzf /path_to_tar/eclipse.tar.gz
Then you should create symlink in /usr/local/bin/ to execute eclipse. Create a file named eclipse in /usr/local/bin/, fill it with this:
#!/bin/sh
ECLIPSE=/usr/lib/eclipse/eclipse
if [ ! -d ~/.eclipse/ ] ; then
    $ECLIPSE -clean -initialize || exit $?
fi
exec $ECLIPSE "$@"
Give execute permission to this file:
chmod +x /usr/local/bin/eclipse
Now you should be able to run eclipse from terminal using eclipse command:
eclipse
c0rp
  • 10,010
