25
How can I add line numbers to Emacs?
Please explain, I'm an absolute beginner.
AKGMA
  • 385
If you're running it in default mode, it's in the menu: Options > Show/Hide > Line Numbers. Then Options > Save Options to save it for future sessions.
If you're running it in a terminal (emacs -nw), then it's M-x line-number-mode. M- is usually the Windows key, but may be Alt, or you can press Esc followed by x.
(Edit: The above only affects the mode line. For line numbers in the margin, you want M-x linum-mode, or more likely (setq global-linum-mode t) in your ~/.emacs.)
geekosaur
  • 11,777
21
Add (global-linum-mode t) to ~/.emacs.d/init.el
