To set up a simple wifi hotpsot for an Android phone use ap-hotspot as detailed here.
It works for me ;-)
Basically, install it:
sudo add-apt-repository ppa:nilarimogard/webupd8
sudo apt-get update
sudo apt-get install ap-hotspot
Use ppa's at your own risk
Start it with:
sudo ap-hotspot start
You can also stop it:
sudo ap-hotspot stop
and configure it:
sudo ap-hotspot configure
Android does not seem to support the hotspot created in Ubuntu - <rant>even though I have never had this trouble with another operating system</rant>
Ubuntu 14.04 apparently needs a special fix as well (bear in mind it does not have the security fixes in the newer versions).
For Ubuntu 14.04:
also the hostapd version in Ubuntu 14.04 is buggy and doesn't
work properly. To get AP-Hotspot to work with hostapd in Ubuntu 14.04,
you need to downgrade hostapd and use apt to hold the package so it's
not upgraded (thanks to spupuz for the tip!). To do this, use the
following commands:
64bit:
cd /tmp
wget http://old-releases.ubuntu.com/ubuntu/pool/universe/w/wpa/hostapd_1.0-3ubuntu2.1_amd64.deb
sudo dpkg -i hostapd*.deb
sudo apt-mark hold hostapd
32bit:
cd /tmp
wget http://old-releases.ubuntu.com/ubuntu/pool/universe/w/wpa/hostapd_1.0-3ubuntu2.1_i386.deb
