I'm trying to find the best graphics card for my ATI Radeon HD 7730M card (My machine has hybrid graphics, should I worry about installing a suitable driver for the intel vga too ?) because I'm having a bad experience with the open source version. It's like lots of crossing lines appear for a very fast glimpse and then disappear instantly without a trace. It's nothing big, but it's not usual nor acceptable. This happens randomly, every few minutes.
Here is as much information I could gather about my vga card by running the following commands:
$ sudo lshw (Only relevant information is listed here):
*-display
description: VGA compatible controller
product: Chelsea LP [Radeon HD 7730M]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
bus info: pci@0000:01:00.0
version: 00
clock: 33MHz
capabilities: pm pciexpress msi vga_controller bus_master cap_list rom
configuration: driver=radeon latency=0
$ Xorg -version
X.Org X Server 1.14.5
Release Date: 2013-12-12
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.2.0-37-generic x86_64 Ubuntu
Current Operating System: Linux MG-7520SE 3.11.0-15-generic #23-Ubuntu SMP Mon Dec 9 18:17:04 UTC 2013 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.11.0-15-generic.efi.signed root=UUID=fdebe919-101f-4bc7-84c1-f209c05c18c8 ro quiet splash acpi_osi=Linux acpi_backlight=vendor quiet splash vt.handoff=7
Build Date: 17 December 2013 10:06:15AM
xorg-server 2:1.14.5-1ubuntu2~saucy1 (For technical support please see http://www.ubuntu.com/support)
Current version of pixman: 0.30.2
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
$ lspci -nnk
01:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Chelsea LP [Radeon HD 7730M] [1002:682f]
Subsystem: Dell Device [1028:0572]
Kernel driver in use: radeon
man radeon (I can't find my card listed anywhere !)
SUPPORTED HARDWARE
The radeon driver supports PCI, AGP, and PCIe video cards based on the following ATI/AMD chips (note: list is non-exhaustive):
R100 Radeon 7200
RV100 Radeon 7000(VE), M6, RN50/ES1000
RS100 Radeon IGP320(M)
RV200 Radeon 7500, M7, FireGL 7800
RS200 Radeon IGP330(M)/IGP340(M)
RS250 Radeon Mobility 7000 IGP
R200 Radeon 8500, 9100, FireGL 8800/8700
RV250 Radeon 9000PRO/9000, M9
RV280 Radeon 9200PRO/9200/9200SE/9250, M9+
RS300 Radeon 9100 IGP
RS350 Radeon 9200 IGP
RS400/RS480 Radeon XPRESS 200(M)/1100 IGP
R300 Radeon 9700PRO/9700/9500PRO/9500/9600TX, FireGL X1/Z1
R350 Radeon 9800PRO/9800SE/9800, FireGL X2
R360 Radeon 9800XT
RV350 Radeon 9600PRO/9600SE/9600/9550, M10/M11, FireGL T2
RV360
RV370 Radeon X300, M22
RV380
RV410 Radeon X700, M26 PCIe
R420
R423/R430 Radeon X800, M28 PCIe
R480/R481
RV505/RV515/RV516/RV550
Radeon X1300/X1400/X1500/X1550/X2300
R520
RV530/RV560 Radeon X1600/X1650/X1700
RV570/R580
RS600/RS690/RS740
Radeon X1200/X1250/X2100
R600
RV610/RV630 Radeon HD 2400/2600/2700/4200/4225/4250
RV620/RV635 Radeon HD 3410/3430/3450/3470/3650/3670
RV670
RS780/RS880 Radeon HD 3100/3200/3300/4100/4200/4250/4290
RV710/RV730
RV740/RV770/RV790
CEDAR Radeon HD 5430/5450/6330/6350/6370
REDWOOD
JUNIPER Radeon HD 5750/5770/5830/5850/5870/6750/6770/6830/6850/6870
CYPRESS
HEMLOCK Radeon HD 5970
PALM Radeon HD 6310/6250
SUMO/SUMO2 Radeon HD 6370/6380/6410/6480/6520/6530/6550/6620
BARTS Radeon HD 6790/6850/6870/6950/6970/6990
TURKS Radeon HD 6570/6630/6650/6670/6730/6750/6770
CAICOS Radeon HD 6430/6450/6470/6490
CAYMAN Radeon HD 6950/6970/6990
ARUBA Radeon HD 7000 series
TAHITI Radeon HD 7900 series
PITCAIRN Radeon HD 7800 series
VERDE Radeon HD 7700 series
OLAND Radeon HD 8000 series
HAINAN Radeon HD 8000 series
BONAIRE Radeon HD 7790 series
KAVERI KAVERI APUs
KABINI KABINI APUs
Now as far as I could get, fglrx stable version of the driver supports only up to version 1.13 of xserver and I'm running 1.14, so I'm trying to use the open-source one instead. I opened the system's settings dialog, opened the "Software & Updates" dialog from there and switched to the "Additional Drivers" tab, where I confirmed that I'm using the open source version of ati drivers. I suppose their website is this one.
Now the latest version on the mentioned site is 7. How can I verify that I'm using the latest version ?
Based on this answer, I installed the ppa repository for the open source driver and ran sudo apt-get update && sudo apt-get upgrade, but nothing was downloaded. So I'm supposedly running the latest version, so how can I verify that ?
