First of all, sorry for my English.
I'm trying to add an icon in the gnome-shell's dock (with Ubuntu 13.04 and 13.10) for the command line app xkill, but it doesn't work, since it is a terminal application. But if I create the menu entry as a "terminal application" (writting it in a .desktop file or throghout the "Main Menu" application), it opens, consequently, a terminal with the message: "Select the window bla bla bla....".
What I really want is a more natural and direct way for closing a blocked window by force, and not by means of a terminal.
For older versions of gnome-shell there was a little extension which made it (adding a little icon in the top bar), but it exists no longer (or I haven't found it).
Solution? Thanks.
ABu
  • 255
Create a launcher with the command gnome-desktop-item-edit --create-new ~/Desktop as suggested by @maythux, but just add /usr/bin/xkill as the command. (Do NOT use gnome-terminal -e).
This creates the launcher on the desktop.
Simply drag it to the dock and remove it from the desktop if you like.
I use Easystroke Gesture Recognition for that purpose. Install it then pick up Gesture Button >button 3 from preferences tab, it lets you run commands dragging right button and drawing a figure like line, circle or whatever you like then switch to Action tab and record a guesture dragging right button, finally add commad
sudo xkill
that's all.
Whenever you want to kill a frozen window, just drag right button and draw the shape you attained, you will get a x shape cursor to kill the window.
kenn
  • 5,232
You can do this trick to get your need(it still use the terminal but you have not to take care about.)
First create a launcher on desktop by using the old GUI dialog.
Using ALT+F2 type:
This will start the dialog( Create launcher):
In the Name field put any name you like.
In the command field put the command gnome-terminal -e "xkill" or if you have other terminal emulators you can use like xterm or whatever.
Now drag and drop the created launcher to the Unity launcher and try it :).
Another Solution:
Here is a scipt to do what you like and they have a unity launcher and you can learn how to install and use
Maythux
  • 87,123
