I had 3 Partition(C(150gb),D(350gb),E(400gb)) and Windows 8.1 installed on C drive.
I replaced Windows 8 with Ubuntu 13.04.
Now I have only one file system(900gb).
Is there any way to access data of D and E partition from Ubuntu?
Is it possible to get back D,E partition if i replace Ubuntu with windows?
Has Ubuntu formatted my entire hard disk?
$df -h
/dev/sda2       909G  2.7G  861G   1% /
none            4.0K     0  4.0K   0% /sys/fs/cgroup
udev            3.9G  4.0K  3.9G   1% /dev
tmpfs           788M  860K  787M   1% /run
none            5.0M     0  5.0M   0% /run/lock
none            3.9G  156K  3.9G   1% /run/shm
none            100M   44K  100M   1% /run/user
/dev/sda1        93M  121K   93M   1% /boot/efi
Oli
  • 299,380
df will only show you mounted partitions.
I'd use gparted or fdisk -l to work out what's on a disk.
But sda2 being so big suggests that yes, you've replaced the all old partitions instead of resizing them (or just replacing one).
You can reinstall Windows (which will likely replace Ubuntu), or attempt some sort of data recovery but there isn't a magic way to just undo what's been done. You've overwritten data. There's usually no coming back from that.
Oli
  • 299,380
