26
I am trying to use my ext4 USB drive but Ubuntu 13 is currently mounting it with write permission only for root so with my normal user I can't write to it, without sudo.
The first place I checked was dconf-editor which has the following options
  • automount
  • automount-open
  • autorun-never
  • autorun-x-content-ignore
  • autorun-x-content-open-folder
  • autorun-x-content-start-app
and it seems to me there should be an option in there to control if I can write to the mounted USB drive, but no.
I also made sure my user is in the relevant groups: fuse and plugdev
I've searched most of the internet and can't find a solution to change the permissions given by the mount operation. There's literally nobody out there having this problem incredibly. A ton of people have issues because their drives mounts totally read-only, but not this way with only root write permission.
I can't see any way of controlling what happens. I looked at setting the mount options using gnome-disks but drew a blank.
It's not in fstab but it does appear in the mount list or /etc/mtab:
/dev/sdb1 /media/adam/WDPassport2T ext4 rw,nosuid,nodev,uhelper=udisks2 0 0
This is what appears in syslog if it helps:
kernel: [111522.196770] usb 2-1: USB disconnect, device number 6
kernel: [111525.384020] usb 2-1: new high-speed USB device number 7 using ehci-pci
kernel: [111525.565220] usb 2-1: New USB device found, idVendor=1058, idProduct=0820
kernel: [111525.565225] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
kernel: [111525.565227] usb 2-1: Product: My Passport 0820
kernel: [111525.565229] usb 2-1: Manufacturer: Western Digital
kernel: [111525.565231] usb 2-1: SerialNumber:  575832314141334A34383631
kernel: [111525.565729] usb-storage 2-1:1.0: USB Mass Storage device detected
kernel: [111525.566203] scsi9 : usb-storage 2-1:1.0
mtp-probe: checking bus 2, device 7: "/sys/devices/pci0000:00/0000:00:1d.7/usb2/2-1"
mtp-probe: bus: 2, device: 7 was not an MTP device
kernel: [111526.564697] scsi 9:0:0:0: Direct-Access     WD       My Passport 0820 1007 PQ: 0 ANSI: 6
kernel: [111526.565063] scsi 9:0:0:1: Enclosure         WD       SES Device       1007 PQ: 0 ANSI: 6
kernel: [111526.568096] sd 9:0:0:0: Attached scsi generic sg2 type 0
kernel: [111526.568202] ses 9:0:0:1: Attached Enclosure device
kernel: [111526.568263] ses 9:0:0:1: Attached scsi generic sg3 type 13
kernel: [111531.263108] sd 9:0:0:0: [sdb] 3906963456 512-byte logical blocks: (2.00 TB/1.81 TiB)
kernel: [111531.265100] sd 9:0:0:0: [sdb] Write Protect is off
kernel: [111531.265105] sd 9:0:0:0: [sdb] Mode Sense: 47 00 10 08
kernel: [111531.266473] sd 9:0:0:0: [sdb] No Caching mode page found
kernel: [111531.266479] sd 9:0:0:0: [sdb] Assuming drive cache: write through
kernel: [111531.272224] sd 9:0:0:0: [sdb] No Caching mode page found
kernel: [111531.272230] sd 9:0:0:0: [sdb] Assuming drive cache: write through
kernel: [111531.284885]  sdb: sdb1
kernel: [111531.288219] sd 9:0:0:0: [sdb] No Caching mode page found
kernel: [111531.288223] sd 9:0:0:0: [sdb] Assuming drive cache: write through
kernel: [111531.288227] sd 9:0:0:0: [sdb] Attached SCSI disk
kernel: [111531.751588] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
udisksd[3131]: Mounted /dev/sdb1 at /media/adam/WDPassport2T on behalf of uid 1000
Adam
  • 1,149
A possible reason could be that you formatted/created the storage disk with a tool with root privilege and so the file-system created was owned by the root.
Let's have a look at the o/p of your ls commands:
$ ls -ld /media/adam/WDPassport2T
drwxr-xr-x 4 root root 4096 Jan 15 16:57 /media/adam/WDPassport2T
$ ls -l /media/adam/WDPassport2T
total 20
drwxr-xr-x 2 root root 4096 Jan 15 16:57 backuppc
drwx------ 2 root root 16384 Jan 15 15:37 lost+found
The file-system is owned by the root, as indicated by ls -ld for your mount WDPassport2T and the permission string drwxr-xr-x shows the owner root has the RW permissions while, the members of group root along with the world/others will only have R-permission.
To solve you could change the permissions with chmod or just change the ownership recursively, and this is what I've shown below:
sudo chown <username>:<groupname> -R /path/to/target
which in your case would be:
sudo chown adam:adam -R /media/adam/WDPassport2T/
Now if you need, you may also set the permissions with chmod:
find /media/adam/WDPassport2T/ -type f -execdir chmod 666 -Rv {} +
(which gives owner, group and the world RW permissions for all the files in the target.)
find /media/adam/WDPassport2T/ -type d -execdir chmod 777 -Rv {} +
(which gives owner, group and the world RWX permissions for all the directories in the target.)
Reference:
Official Ubuntu Documentation: File Permissions
rusty
  • 16,917
Have you tried re-formating the drive with your own permissions?
First, check your user id:
sudo id -u red
It should give "1000"
Next, unmout the drive in filemanager.
Be careful, you will lose all your data with the next comand
sudo mkfs.ext4 /dev/sdx1 -E root_owner=1000:1000
Mount the drive and you should be able to write files and folders
ubfan1
  • 19,049
red
  • 39
Most partitioning & formatting tools (like Gparted) requires the root privileges.
File systems like ext4, ext3 stores file ownership information with the pen drive itself. (But the ntfs, fat32, fat16 does not have a security like that)
In this case you have to change the permission by using the following command in the terminal.
chown -hR nobody:nogroup /media/adam/WDPassport2T/
by setting the user as "nobody" & the group as "nogroup" it will fix the similar issues with permissions / ownership when plugged the disk into another box.
for more info see the manual page for chown command (use "man chown" )
Thadika
