it is a very similar problem to that described here:
Crashplan not starting. Fails to find swt-gtk
However I have not succeded at resolving this issue. The error I get in /usr/local/crashplan/log/ui_output.log after I launch the CrashPlanDesktop command to run the GUI for crashplan is the following
[01.15.14 15:46:41.556 ERROR main root ] Failed to launch CPDesktop; java.lang.UnsatisfiedLinkError: Could not load SWT library. Reasons: Can't load library: /tmp/.cpswt/libswt-gtk-4234.so Can't load library: /tmp/.cpswt/libswt-gtk.so no swt-gtk-4234 in java.library.path no swt-gtk in java.library.path /tmp/.cpswt/libswt-gtk-4234.so: /tmp/.cpswt/libswt-gtk-4234.so: failed to map segment from shared object: Operation not permitted
The output of locate swt-gtk is:
/usr/lib/java/swt-gtk-3.7.2.jar
/usr/lib/jni/libswt-gtk-3740.so
/usr/share/doc/libswt-gtk-3-java
/usr/share/doc/libswt-gtk-3-jni
/usr/share/doc/libswt-gtk-3-java/README.Debian
/usr/share/doc/libswt-gtk-3-java/README.gz
/usr/share/doc/libswt-gtk-3-java/changelog.Debian.gz
/usr/share/doc/libswt-gtk-3-java/copyright
/usr/share/doc/libswt-gtk-3-jni/changelog.Debian.gz
/usr/share/doc/libswt-gtk-3-jni/copyright
/usr/share/java/swt-gtk-3.7.jar
/usr/share/java-config/libswt-gtk-3-java
/usr/share/lintian/overrides/libswt-gtk-3-java
/var/cache/apt/archives/libswt-gtk-3-java_3.7.2-2_amd64.deb
/var/cache/apt/archives/libswt-gtk-3-jni_3.7.2-2_amd64.deb
/var/lib/dpkg/info/libswt-gtk-3-java.list
/var/lib/dpkg/info/libswt-gtk-3-java.md5sums
/var/lib/dpkg/info/libswt-gtk-3-java.postinst
/var/lib/dpkg/info/libswt-gtk-3-java.prerm
/var/lib/dpkg/info/libswt-gtk-3-jni.list
