My wireless connection is extremely slow. I am using Ubuntu 13.10, but has been persistent with previous releases as well. http://paste.ubuntu.com/6741980/ http://paste.ubuntu.com/6753596/
Check if you have power management off using:
iwconfig
If you have power management on, disable it (temporarily) using:
sudo iwconfig wlan0 power off
This worked for me (I have a D-Link DWL-G122 adapter).
If you want disable persistently power management you should have /etc/rc.local like this:
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
sleep 10
exit 0
Here you can add the commands that you want run at startup, but the last row must be always exit 0
RobotMan
  • 381
I suggest you try a driver parameter:
sudo modprobe -r rt2800pci
sudo modprobe rt2800pci nohwcrypt=Y
Also, explicitly set your regulatory domain from here: http://en.wikipedia.org/wiki/ISO_3166-1_alpha-2 For example, if your code is FR, then do:
sudo iw reg set FR
I also suggest you experimentally turn off wireless N at the router. When we discover the setting(s) that fix the wireless, we'll tweak a few files and make it persistent.
If the problem persists, let's install a backported driver. Please get a temporary wired ethernet connection. Download this file to your desktop: http://www.kernel.org/pub/linux/kernel/projects/backports/stable/v3.13-rc2/backports-3.13-rc2-1.tar.bz2 Right-click it and select 'Extract Here.' Now open a terminal and do:
sudo apt-get install build-essential linux-headers-generic
cd ~/Desktop/backports-3.13-rc2-1
make defconfig-wifi
make
sudo make install
'make' takes a few minutes; please be patient. Reboot and let us have your report.
chili555
  • 61,330
Not sure if you ever solved this but I had to disable power management on the card using
and the wifi began running at full speed on this laptop. This was on Ubuntu 16.04.
warsong
  • 427
Turning power management off solved it for me on Ubuntu 16.04 as well.
However, I would have to run sudo iwconfig wlan0 power off every time I connect to a network.
For that, I have illustrated a solution at https://askubuntu.com/a/825976/349291
