I need play video in ultra-hd 4K definition (3840×2160 pixels) and my favorite player is VLC.
In Ubuntu 12.04 LTS the latest available version of VLC is 2.0.8 which does not have support for this type of videos and need to update to the latest available version of VLC (2.1.2).
How I can install the latest stable version of VLC on Ubuntu 12.04?
Will
  • 705
5 Answers5
There's now a third-party PPA that provides the most recent build of VLC for Ubuntu 12.04, Ubuntu 12.10, Ubuntu 13.04, Ubuntu 13.10.
Press Ctrl+Alt+T on keyboard to open the terminal. When it opens, run the commands below one by one:
sudo add-apt-repository ppa:djcj/vlc-stable
sudo apt-get update
sudo apt-get install vlc
via: http://ubuntuhandbook.org/index.php/2014/02/install-vlc-2-1-2-ubuntu-12-04/
Check the official VLC PPA.
For the current stable version of VLC that is ppa:videolan/stable-daily
Add it to your system
sudo add-apt-repository ppa:videolan/stable-daily
Update and upgrade / install VLC
sudo apt-get update && sudo apt-get install vlc
To install the latest version add the daily updated
sudo add-apt-repository ppa:videolan/master-daily
Note: The VLC Stable PPA contains the same version of Ubuntu 12.04 repositories (2.0.8) and VLC Master PPA contains 2.2.0 (development version).
kiri
  • 28,986
Maythux
  • 87,123
The VLC stable PPALaunchpad logo does not contain the 2.1.2 version for any release apart from Trusty, which is still in development.
According to the PPA's description, this is intended:
This PPA contains daily builds from the latest VLC maintenance branch.
This PPA is used for test building new and upcoming point releases of VLC that can get into Ubuntu through stable release updates (SRU) or security updates. You don't find major version updates in this PPA (e.g. no update from 2.1.x to 2.2.x).
From the PPA description, emphasis mine
You may need to locate another PPA with the latest stable.
Even the VLC download for Ubuntu page doesn't give instructions to get the latest version.
Ubuntu includes whichever VLC version was the latest at the time the Ubuntu release was frozen (typically about two months before the official Ubuntu upgrade).
Afterward, you can still get security and critical bug fixes, but no further major VLC version updates until the next Ubuntu release.
If you need a more recent version, please consider upgrading Ubuntu.
From VLC media player for Ubuntu
Manually compiling
This is not the best way, unless you really have a need for the latest you should just be happy with the older and stable version.
You may try to download the source from here, compile then install if you're so inclined.
Download the source tar.xz file, there should be a README with instructions.
kiri
  • 28,986
Nate Muench has long maintained repos for VLC releases that haven't made it to the "stable" repos. Currently he has the following, both containing VLC 2.1.2:
aslamK
  • 58
I downloaded the VLC2.1.5.tar.gz, unpacked it in a subfolder of my homedir. I ran the usual ./configure and of course had to tackle all missing libraries. I left Synaptic open to search for the missing files, installed the -dev and repeated the ./configure until I was invited to run the 'make', closed Synaptic and ran a 'sudo make install'. It created the vlc executable shortcut. It left me with two versions of VLC that both run properly as far as I can see. I too have reasons not (yet) to upgrade to 14.04. It takes time to compile but it was worth the effort.
Peter
Peter
