TL,DR: Try installing the libfontconfig1:i386 package.
Packages whose names end in -dev provide header files, which don't help a binary executable to run. There's no need to remove the libfontconfig-dev package, but it's expected that installing it wouldn't help this situation.
The ia32-libs package, available in releases prior to 13.10, provided a number of commonly used 32-bit libraries. Generally speaking, 64-bit software never requires ia32-libs, but since the "64-bit version/edition" of a program just means it's the version for a 64-bit OS and not necessarily that all its native code is 64-bit, such a dependency is possible.
The motivating reason for the ia32-libs package was to provide libraries that are frequently needed by 32-bit programs on a 64-bit system, but would once have been hard to install, since the package manager would only install packages matching the version of Ubuntu installed.
The Ubuntu adopted MultiArch, which facilitates installing both 32-bit and 64-bit packages on the same 64-bit system, using the package manager. MultiArch support started a while ago, but the ia32-libs package was retained, mainly for backward compatibility and for the convenience it provided. (Actually, it was turned into a shortcut for installing the appropriate 32-bit library packages. Users installing it for the first time on a system with MultiArch would install the more descriptively named ia32-libs-multiarch package.)
Well, finally ia32-libs and ia32-libs-multiarch are gone... but you can install install 32-bit libraries (and other packages) on your 64-bit Xubuntu 13.10 system, by specifying the package name and architecture for installation.
You have an error message that specifies a library file that is needed: libfontconfig.so.1. You appear to have only the 64-bit version of that library. (The 32-bit and 64-bit versions are stored in separate directories, in part to allow them both to be installed at the same time.)
To find out what package provides the file, search for it under "Search the contents of packages" at http://packages.ubuntu.com/. This reveals the package that provides it is libfontconfig1. You want to install the 32-bit version of that. Ubuntu's name for the 32-bit PC/Mac architecture is i386 (the 64-bit one, even for Intel processors, is amd64). So you can install this by running:
sudo apt-get update
sudo apt-get install libfontconfig1:i386
Then try running Google Earth again and see what happens.
Related: What happened to the ia32-libs package? (But note, the ia32-libs package remained a transitional package for ia32-libs-multiarch, which provided essentially equivalent functionality until 13.10 Saucy.)
