I recently got an old Dell Latitude-D610 laptop that was running Windows XP, I think, so I completely deleted XP and put Ubuntu on. Before I put Ubuntu on, the wi-fi was working just fine, but now it isn't. In the settings under 'additional drivers' it says "no proprietary drivers are in use on this system" or something like that, and I think that's the problem. I've looked around on this forum and on other places about what to do, and several things said to input the following command:
$ lspci -vvnn | grep 14e4
So I did, and it returns this:
02:00.0 Ethernet controller [0200]: Broadcom Corporation NetXtreme BCM5751 Gigabit   Ethernet PCI Express [14e4:1677] (rev 01)
03:03.0 Network controller [0280]: Broadcom Corporation BCM4306 802.11b/g Wireless LAN Controller [14e4:4320] (rev 03)
I successfully connected to the Internet by sharing my PC's connection through an Ethernet cable, but I've tried many things suggested in these forums and none of them are working. So please, PLEASE do not mark this question as a duplicate, as I've tried almost everything in questions that are indeed very similar to this one, but nothing's working.
Also, I'm not that great at Ubuntu, so if you tell me to do something, please say exactly where it is or how to do it.
Thanks in advance :D
Please get a temporary wired ethernet connection and open a terminal and do:
sudo apt-get update
sudo apt-get install linux-firmware-nonfree
Detach the ethernet, reboot and your wireless should be working. If it is not working, run and post: sudo modprobe b43 && dmesg | grep b43
chili555
  • 61,330
OH MY GOD, IT'S WORKING!
So all I did was
sudo apt-get remove bcmwl-kernel-source
and apparently that was holding me back, because it's working perfectly now! Honestly, you don't know how relieved I am...
Oh, and it told me to type the previously mentioned command at How do I get a Broadcom BCM4306 Wireless card working?
