I'm trying to install Lubuntu 12.04 LTS on my iBook G4 as the OS X 10.4.11 really isn't all that great. I originally tried to use the minimal CD, but that failed as you can see by my question here: https://askubuntu.com/questions/396885/choose-a-mirror-of-the-ubuntu-archive-on-lubuntu-13-10-minimal-install. I think that issue may be caused by this same issue, as there I believe there is no actual internet connection.
So, I decided to try the full 12.04 CD, but I am now getting an error during the boot:
...stuff here (logo and other boot messages - all unrelated)
*starting configure network device
[ 110.081458] b43-phy0 ERROR: Firmware file "b43/ucode5.fw" not found
[ 110.081669] b43-phy0 ERROR: Firmware file "b43-open/ucode5.fw" not found
[ 110.081870] b43-phy0 ERROR: You must go to http://wireless.kernel.org/en/users/Drivers/b43#devicefirmware
and download the correct firmware for driver version. Please carefully read all
instructions on the website.
This is most perturbing. This post says that 10.04 works fine, but since 10.04 is EOL, I don't want to install it. This question suggests using the LiveCD with b43-fwcutter driver and trying to push ESC during the boot to see any errors. Also, would pushing Shift during the boot help any?
I probably will have to blacklist the b43 driver, but I'm not sure how.
There is a bug regarding this here: https://bugs.launchpad.net/ubuntu/+source/casper/+bug/956677 and the suggested solution is blacklisting the driver in the kernel param string, but again, I have no clue how to change the param string. I'm going to research blacklisting a little more, but since I am using the CD, I can't download/install drivers, like I could on USB (my iBook refuses to boot USB, even with Open Firmware hacking.) EDIT: I have looked around for blacklisting
This blog post: http://clusterbleep.net/blog/2012/05/09/ubuntu-12-04-splash-screen-lockup-with-livecd/ is exactly my issue, but I never get a Install/Disk Options screen. Would holding Shift during the boot allow me to get to this? I have to hold C and then enter live to start the LiveCD and then I would hold Shift.
How do I fix this issue? The system is a July 2005 iBook G4 1.33GHz PPC/512MB RAM/40GB HDD/unsure what graphics card/and as can be seen from this issue probably a Broadcom B43 internet chip thingy.
