33
I want to set icon for Launcher. it has file named icon.xpm, but its being ignored by the icon set wizard. I tried to change it to .ico file, but it is still getting ignore. any ideas?
Jorge Castro
  • 73,717
UAdapter
  • 17,967
8 Answers8
57
I added the icon to /usr/share/pixmaps , but the name of the icon was not eclipse.xpm instead it was icon.xpm
In the terminal:
cp /yourEclipseFolder/icon.xpm /usr/share/pixmaps/eclipse.xpm
austin
  • 701
If eclipse is installed from software center (version 3.5.2) copies of the eclipse icon are put into following places:
  • /usr/share/icons/hicolor/16x16/apps/eclipse.png
  • /usr/share/icons/hicolor/32x32/apps/eclipse.png
  • /usr/share/icons/hicolor/48x48/apps/eclipse.png
  • /usr/share/pixmaps/eclipse.png
Maybe copying the icon in this places (with the right size) solves your issue.
Elvis D.
  • 191
Go to terminal and type sudo leafpad /usr/share/applications/eclipse.desktop, then edit the file to replace path_to/icon.xpm in the following example with the file path to your icon:
[Desktop Entry]
Type=Application
Encoding=UTF-8
Name=Eclipse
Comment=Eclipse IDE
Exec=/usr/lib/eclipse/eclipse
Icon=path_to/icon.xpm
Terminal=false
Type=Application
Categories=GNOME;Application;Development;
StartupNotify=true`
For example, mine is /usr/lib/eclipse/icon.xpm.
Magpie
  • 1,295
I copied
/opt/eclipse/plugins/org.eclipse.sdk_3.7.1.v201109091335/eclipse48.png
to
/usr/share/pixmap/eclipse.png
(having extracted eclipse into /opt) and both launcher and desktop eclipse icons reappeared (having mysteriously disappeared).
Note: I had also copied all the sizes as recommended above but it wasn't until I copied into /usr/share/pixmaps that the icon appeared
A.B.
  • 92,125
nix
  • 41
I just had this problem with another program, I placed the .png files in the icon folders:
But still had no icon, then I put one in
Suddenly it worked. The pixmap is the key.
jokerdino
  • 41,732
Ben m
Everything seemed correct in my case, but none of the suggested solutions worked for me, the icon wouldn't become visible in the launcher.
Then I simply removed the comment next to the Icon-line in the eclipse.desktop file and voila! it worked :)
So, my suggestion is, if there is a comment in your Icon-line like:
Icon=/opt/eclipse/icon.xpm # fill in path to logo
then remove the comment so it looks like:
I don't know why the comments work for the other lines (e.g. in the Exec-line it works). Maybe a bug.
hope it helps someone!
Jane
Just copy the icon to
~/.icon
folder and it should work. Copying eclipse.xpm to ~/.icon folder worked for me.
A.B.
  • 92,125
Simply, rename icon.xpm to icon.jpg inside the eclipse folder no matter where it is. Now try.
For more details go through the following note :-
  1. First, search alacarte aka Main Menu on Dash.
    You will see a list of applications and checked Items.
    Go to New Item, fill as follows -
            Name: Eclipse                         #of your choice
            Command: /home/leo/Downloads/eclipse
            Comment:                             #as you wish
Set path to the eclipse directory where you have it extracted.
Mine is inside Downloads.
  1. Now, you see an icon there itself. Click it and select icon.jpg inside your eclipse folder. (You need to browse through)
  2. Now search for eclipse and you will see that on Dash with the desired icon and you can pin it to Launcher or have it on Desktop.
Dash -> Main Menu -> New Item -> Fill up Name, Command and Comment and click on icon -> browse and select icon.jpg-> close window
Have fun!
Leo_95
