21
The wireless connection in my house unfortunately often disappears, requiring a wireless router reboot.
Making this worse is that my ubuntu media pc, does not automatically reconnect to the wireless network when it's been gone, and then comes up about a minute later. The network in question is setup as "connect automatically" in the network settings.
If I manually select my wireless network, using the wireless icon in the topright of my screen, everything works fine, until the next time that wireless goes down.
I'm looking for a way so I don't have to remember to do this manually all the time.
Jorge Castro
  • 73,717
9 Answers9
This seems to be posted all over the net with no good solutions. I guess the best fix/workaround is to make it check for internet connectivity and if it is not there then reconnect. I did this via a ping test to google.com and then I simply made it restart networking. Code is not tested (the restart part and the cron part, if statement tested), so I'll just wait for it to disconnect at some point. I have an Ubuntu Server 12.10, so no GUI, and is a pain to connect monitor and keyboard every time the wireless stuffs up.
Cron part done via webmin so Idk much about it. Script is as follows:
# edited by dim_voly for networking restart on no pingback every 5 mins
#!/bin/bash
# Name of File: networkingCron
# Purpose: to check if the internet is up (via ping test to google) and if not, restart networking service
# this script is invoked via cron, ideally every 5 mins.
#check if there is internet via ping test
if ! [ "`ping -c 1 google.com`" ]; then #if ping exits nonzero...
   sudo service networking restart #restart the whole thing
   echo Networking service restarted due to no ping response from google.com
fi
echo Script 'networkingCron' completed, if no message above then there was no network restart.
# dunno how to restart the wifi only since that is the only active connection that server uses.
# also I don't think those echos go anywhere
Make sure to run as root and make sure the script has execute (u+x) permissions.
links:
derHugo
  • 3,376
  • 34
  • 52
dim_voly
  • 161
Just create a new file vi /root/checkwanup and add this content:
#!/bin/bash
wlan=`/sbin/ifconfig wlan0 | grep inet\ addr | wc -l`
if [ $wlan -eq 0 ]; then
    /sbin/ifdown wlan0 && /sbin/ifup wlan0
else
    echo interface is up
fi
Then chmod 555 /root/checkwanup and add it to your crontab:
crontab -e
*/15 * * * * /bin/bash /root/checkwanup
Source: http://sirlagz.net/2013/01/10/script-wifi-checker-script/
derHugo
  • 3,376
  • 34
  • 52
DougD
  • 71
I had a similar problem with my laptop's Intel Wireless WiFi 5100 half height card and the driver iwlagn driver. This problem is a known issue with the iwlagn driver, and the best workaround is to disable 802.11n on the card.
To disable 802.11n on this card create/edit your /etc/modprobe.d/options.conf file:
sudo -H gedit /etc/modprobe.d/options.conf
And add the following to it.
options iwlagn 11n_disable=1 11n_disable50=1
Eliah Kagan
  • 119,640
Mike
  • 707
More modern version of @DougD script
#!/bin/bash
wlan=$(/sbin/ifconfig wlan0 | grep inet\ addr -c)
if [ "$wlan" -eq 0 ]; then
else
fi
derHugo
  • 3,376
  • 34
  • 52
hawk
  • 131
This is an alternative using service network-manager restart:
#!/usr/bin/env bash
# 1. copy this script into
# /usr/bin
# 2. change permissions
# root:/usr/bin# chmod +x checkwifi.sh
# 3. add to cron as root
# sudo su
# crontab -e
# add this to check your wifi every minute
# * * * * * /usr/bin/checkwifi.sh
is_ok=$(/sbin/ifconfig wlp2s0 | /bin/grep inet\ addr -c)
if [ "$is_ok" -eq 0 ] ; then
    # restart
    /usr/sbin/service network-manager restart
    # wifi is ok
    /bin/echo $(date) "wifi was restarted" >> /user/user/Dropbox/wifi.log
    /bin/echo $(/sbin/ifconfig wlp2s0) >> /home/user/Dropbox/wifi.log
else
    # wifi is ok
    /bin/echo $(date) "wifi is ok" >> /home/user/Dropbox/wifi.log
fi
derHugo
  • 3,376
  • 34
  • 52
auraham
  • 197
Another network manager solution, explicitly testing on a wifi connection (beware, there may be multiple adapters though, then adapt). Tested Ubuntu 22.04.
#!/bin/bash
numConnections=$(/usr/bin/nmcli con show --active | grep wifi | wc -l)
if [ $numConnections == 0 ] then echo "Wifi not connected, trying to restart" /usr/bin/nmcli radio wifi off # might not be necessary /usr/bin/nmcli radio wifi on else echo "Wifi still connected" fi
As above, add to (user) crontab, crontab -e. Add an adaptation of this line to check your wifi every minute (be sure to line break after the new line):
* * * * * /bin/bash /path/to/testIfWifiOnOrRenable.sh
Note, what you also should be aware of, is the power save behaviour for WiFi connections of Ubuntu. It can be activated/deactivated in /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf, by setting
wifi.powersave = 2
instead of wifi.powersave = 3, see also https://unix.stackexchange.com/a/315400
DomTomCat
  • 111
You might want to have a look at using wpa_supplicant instead of network-manager, but that doesn't really matter when on a media-center. wpa_supplicant isn't as flexible as network-manager but afaik it doesn't give up after trying three times. have a look at this answer.
Here is my version - it works with NetworkManager:
#!/bin/bash
    /usr/bin/nmcli nm wifi off && /usr/bin/nmcli nm wifi on
fi
derHugo
  • 3,376
  • 34
  • 52
Chris
All the scripted solutions are crappy because they are either very slow (1 minute delay, hmm, I'd rather start ifdown && ifup by hand than wait) or complex and buggy (I don't see such here btw).
The only normal solution is using iwd instead of wpa_supplicant. How you set it up depends on your needs. F.ex. you can set it as NetworkManager backend in /etc/NetworkManager/conf.d/wifi_backend.conf (be aware of bugs):
[device]
wifi.backend=iwd
From LWN article:
Iwd will be the only program that performs WiFi scanning on systems where it is running; that differs from systems using wpa_supplicant, where higher-level software must also scan for networks. With iwd, that work has all been pushed to a single level where good decisions can be made.
midenok
  • 848
  • 15
