I had windows 7 in C drive and windows 8.1 in D drive. But I installed Ubuntu 13.10 and the system got formatted. I wanted to have 3 OS. But lost the other two. I didnt make any partitions.Now I want to uninstall Ubuntu and install windows 8.1, How to do it?> P.S : I dont know much about partioning.
Asked
Active
Viewed 658 times
If you have Windows-8.1 installation disc with you format the ubuntu partition using ntfs with it.
After that install windows-8 on that partition. May be if you can clarify me more like
1.Which drive got formatted.
2.Installed via WUBI installer or direct etc
Then I can help you more
Also if u need 3 OS then you need to have 3 partitions in your hard-drive Every partition for separate OS.
If you don't Want to do it then It can also be done in 2 partitions Install Ubuntu Inside windows via WUBI installer.
Arunesh Singh
- 111
