-1
I've completely destroyed everything and now php wont install.
I had php5.4 and everything was great. I then needed to run Magento locally which wasnt working.
I saw one of the requirements was php5.3 so I downgraded using a script i found online but then PDO wasnt working.
I stuffed about for a few hours following what people said online, eventually nothing was working so i purged php to do a fresh install of php5.4 to start again from scratch and figure out my problems.
After i purged, i came to reinstall Php5 using apt-get install php5. Once the script ran i got the following output:
Reading package lists... Done
Building dependency tree
 php5 : Depends: libapache2-mod-php5 (>= 5.4.9-4ubuntu2.4) but 5.3.10-1ubuntu3 is to     be installed or
                 libapache2-mod-php5filter (>= 5.4.9-4ubuntu2.4) but it is not going to be installed or
             php5-cgi (>= 5.4.9-4ubuntu2.4) but it is not going to be installed or
             php5-fpm (>= 5.4.9-4ubuntu2.4) but it is not going to be installed
    Depends: php5-common (>= 5.4.9-4ubuntu2.4) but 5.3.10-1ubuntu3 is to be installed
I then googled for ages and ran commands like clean, update, upgrade, -f install and a few others. I come back to install php and i get the same error.
How can I reinstall Php so it works again.
Try this command,
sudo aptitude install php5
It will install php5 along with it's dependencies.
Avinash Raj
  • 80,446
try this :
sudo rm -r /var/lib/apt/lists/* && sudo apt-get update
then try to install your
sido
