Whenever I try to install codeblocks I get this error:
 codeblocks : Depends: codeblocks-common (= 12.11-3) but it is not going to be installed
kiri
  • 28,986
Install codeblocks-common first, then install codeblocks.
Jet86
  • 317
You need to install codeblocks-common first. You can do this either through Ubuntu Software Center or terminal using the following command
sudo apt-get install codeblocks-common
or you can handle the unmet dependecies with the following command
sudo apt-get -f install
