after changing compiz configs - the panels disappeared
I just see my files on the desktop, Problem I cant open settings to reset the compiz settings or what ever happend. How do I solve this?
Kim
  • 31
You can reset your Unity configuration with unity --reset (via How do I reset my Unity configuration?)
Egil
  • 14,522
Based on the contents of unity --help, running unity --reset will clear any custom settings you use in the unity plugin.
When my panel disappears, I instead run unity --replace
Unity's --reset switch is deprecated. To reset Unity's settings run the following 2 commands:
(This should only apply to 13.04 and 13.10, I'm not sure about older versions)
  1. Install dconf if you don't have it: sudo apt-get install dconf-tools
  2. Reset compiz settings: dconf reset -f /org/compiz/ (This is not a path on your disk, but it just identifies compiz-specific settings)
  3. Restart Unity: setsid unity
  4. Never use compiz again (You can obviously skip this step)
  1. create a launcher for terminal, with the command gnome-terminal
  2. then Open compiz in terminal with the command ccsm,
  3. go to preferences then click the Reset to Defaults
this work fine for me. :)
