-2
How can you keep different partitions for Windows and Ubuntu.
I'm not sure if I want to switch to full Linux already, so I need to try it before.
Never did it before, can you guide me?
Braiam
  • 69,112
I hope this works for you. Upon booting from a live CD:
  1. On the Ubuntu Setup screen, hit Enter to Start or install Ubuntu.
  2. Double-click Install on the Desktop.
  3. Go through the installation wizard (if using Ubuntu 8.04 until you reach step 4). Ubuntu 8.10 installs a dual-boot by default installation.
  4. If using Ubuntu 8.04, then at step 4, select the first option, Guided - resize and you can specify how much disk space you want the new partition to use as shown below.
  5. Continue through the rest of the steps and click Install on step 7.
  6. Click Restart Now and remove the CD from CD-ROM drive.
  7. Done! Every time you start up your computer now you will be prompted to select what operating system you want to start up through the GRUB Bootloader screen as seen below.
