I had a text file hello.txt which contains about 100 lines.I accidentally deleted all the lines by running echo > hello.txt
Now i want to recover all the 100 lines.Is there any way to recover the lines in that file using terminal commands?
You can not get back the contents. There is no mercy.
But search for backup files. If you are lucky enough there will be a file named hello.txt~ for hello.txt in the same directory. Those files are usually created by text editors like gedit or emacs when you edit a file.
If you have such backup file you can get the contents back (you may get back only a part also). Use the following in the terminal,
mv hello.txt~ hello.txt
It is better to have even a part than losing it completely.
tl;dr Skip to the end for the working solution.
I accidentally truncated a file using gedit. It was truncated from 1800 kB down to 25 kB.
I wanted to share a few recovery techniques I attempted. This isn't meant to be a definitive answer, more a collection of answers to try. This is similar to this post.
sudo mount -o remount,ro /
The mount command failed. with error mount: / is busy.
I recommend the drastic step of just hard powering off your machine. Yes, drastic! But I don't know how long the remnants of the truncated file will be around. They may be overwritten at any moment. Boot up into the Ubuntu LiveCD.
Per a comment here, I ran telinit 1 which dropped down to init level 1. This only complicated things so I don't recommend doing telinit 1. I recommend the hard power down.
Following this blog post and this email thread, try using ext3grep.
However, ext3grep failed for me. I was only able to recover the truncated file.
sleuthkit is cool toolset. You'll probably have to install it. Again, this get's tricky if the truncated file was the / mount. Again, I recommend hard powering off and then running a LiveCD.
Using this blog post, and this blog post, the instructions are essentially
apt-get install sleuthkitstat truncated-file | grep InodeINODE_NUMBER)cp -a truncated-file truncated-file.oldrm truncated-filedebugfs /dev/disk-devicestats BLOCKS_PER_GROUP)imap <$INODE_NUMBER>BLOCK_NUMBER)blkls to copy the blocks to a fileblkls /dev/disk-device $BLOCK_NUMBER-$(echo '$BLOCK_NUMBER+$BLOCKS_PER_GROUP-1' | bc) > recovered-fileBut sleuthkit did not work for me. Only the truncated file was recovered.
From this post, grep for some known string in the truncated file. This is the only method that worked for me.
grep -a -A 1000 -F 'some known string' \
/dev/disk-device > recovered-file
Surprisingly simple, eh?
Sorry friend, It's impossible...
You can recover deleted files but you can't recover a file with deleted content..
