53
For 11.04, I did a fresh install of my system. Part of that install was to install rvm, which sticks a rvm.sh in /etc/profile.d/. This doesn't work as /etc/profile (which loads each +r in /etc/profile.d/*.sh) is not being loaded. According to the documentation, the profile is only sourced if bash is run in login. To verify this, I invoked bash --login, after which rvm was available.
This has worked for me in previous versions of Ubuntu without any configuration. That is, a fresh install of 10.10 will correctly source profile/.d.
My question is: is there anything I'm doing wrong, or are there some new assumptions being made in Natty that have broken this? My current workaround is to source /etc/profile in ~/.bashrc (which is awful as profile is meant to load before bashrc's, but does the trick).
Jesse Nickles
  • 462
Marc
  • 533
6 Answers6
59
Per default, gnome-terminal does not start bash as a login shell (I assume you mean bash started inside a gnome-terminal). That means bash will not read /etc/profile or ~/.profile. As you have correctly observed, bash will read those files if started as a login shell.
The quick fix to your problem is to configure gnome-terminal to start bash as a login shell so it will read /etc/profile. To do so click on the Edit menu of gnome terminal, then "Profile Preferences", then enable "Run Command as a login shell".
I do not recommend doing this because it messes up the distinction between ~/.profile and ~/.bashrc.
Ideally ~/.bashrc should do setup for bash, typically required everytime bash is started. While ~/.profile should do stuff which is not bash and required only once, during login.
For more information read this question and answer at superuser talking about the difference between bashrc and profile.
From your problem description it seems that the rvm script needs to be loaded only once, during login. As far as I know Ubuntu has configured the graphical login to read /etc/profile/ and ~/.profile. That means, after logging out and a logging in once, the rvm script should be active.
If it still doesn't work, then perhaps the rvm script needs to be loaded for every bash session. If that is the case then bashrc is the more appropriate place for the script.
Lesmana
  • 18,754
There is, however, a file /etc/bash.bashrc that is read by gnome-terminal and is the "system-wide .bashrc file for interactive bash(1) shells."
My call to the rvm function, [[ -s "$HOME/.rvm/scripts/rvm" ]] && . "$HOME/.rvm/scripts/rvm" , went in there, and works just fine for the couple of users on that system.
Dmitri
  • 181
Installing RVM as multiuser requires the user to run this command:
(because Ubuntu does not source /etc/profile.d at the login)
echo '[[ -s "/etc/profile.d/rvm.sh" ]] && . "/etc/profile.d/rvm.sh" # Load RVM function' >> ~/.bashrc
if you have ZSH or OH-MY-ZSH, your profile is /etc/zprofile
I have actually found for those who do not like to fully restart their boxes unless it is absolutely required the following...
You do not need to restart the whole machine to have changes to /etc/profile take effect. All you need is to have your XWindows Desktop GUI restart so it re-reads configs (as it would if it were to be started as part of a system-wide restart).
For me I use xUbuntu which uses LightDM but you can sub in whatever executable calls your current desktop.
First, you can not use a terminal emulator from inside the desktop GUI itself to do this (at least not with LightDM) you need to either use SSH or a secondary console (if you hold Ctrl + Alt and hit an F Key or number key you should drop away from your graphical desktop login or screen to a plain terminal window). I also suggest you close out any remote desktop stuff like VNC if you are using SSH (obviously SSH can be connected you just do not want an open VNC window to be polling display 0 while it is trying to restart as this may hang the restart while it waits for you to terminate the VNC session).
I do this all the time with SSH and it is a big lifesaver especially when you are not physically by your machine and do not feel like waiting for a full restart and reconnecting :-D
Now the easy part once in a "secondary" terminal or SSH issue: (Yes, this will kill your current session, be sure you do not mind, save any open documents or work)
sudo service lightdm restart
wait a minute as it kills the desktop and then starts it again (this can take a few good seconds as things are stopped and then executed again on start)
That's it, now when you head back to either console 0 or you go to to use VNC to connect again you will be greeted by the login prompt and login as normal and if you open a terminal emulator and go to issue your command you should now have no problems as everything was re-sourced just as if you did a full machine restart.
Just remember, if you issue sudo service lightdm restart [or stop, start, whatever] from within the desktop environment itself using a terminal emulator the command will just hang there and nothing will seem to be happening. This is because you are currently using that console (aka display) 0 and so it can not fully go down and come back up as it is waiting for the desktop to not be in use before it runs the command.
Last Note: I have not tried to issue restart on the environment from within the desktop in a terminal emulator and then switch to another console that may then restart it, but if you are already going to switch the console then why not just run the command from there as it should be anyways?
Pariah
  • 17
-4
echo ". .profile" >> ~/.bashrc
And then open another window. I think this is the easy approach.
chris
