I have just installed Ubuntu 13.10 x64. After installing nvidia-319-updates and nvidia-settings-319-updates I don't have anything in additional drivers tab of software and updates. Additionally when I run nvidia-settings I get this:
You do not appear to be using the NVIDIA X driver. Please edit your X configuration file (just run nvidia-xconfig as root), and restart the X server.
I don't have nvidia-xconfig
/var/log » sudo nvidia-xconfig
sudo: nvidia-xconfig: command not found
/var/log »      dpkg -l |grep nouveau ; dpkg -l |grep nvidia        d21d3q@zkomp
ii  libdrm-nouveau2:amd64                     2.4.46-1ubuntu1                          amd64        Userspace interface to nouveau-specific kernel DRM services -- runtime
ii  xserver-xorg-video-nouveau                1:1.0.9-2ubuntu1                         amd64        X.Org X server -- Nouveau display driver
ii  bumblebee-nvidia                          3.2.1-3                                  amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
ii  nvidia-319-updates                        319.60-0ubuntu1                          amd64        NVIDIA binary Xorg driver, kernel module and VDPAU library
ii  nvidia-common                             1:0.2.83                                 amd64        transitional package for ubuntu-drivers-common
ii  nvidia-cuda-dev                           5.0.35-7ubuntu1                          amd64        NVIDIA CUDA development files
ii  nvidia-cuda-doc                           5.0.35-7ubuntu1                          all          NVIDIA CUDA and OpenCL documentation
ii  nvidia-cuda-gdb                           5.0.35-7ubuntu1                          amd64        NVIDIA CUDA GDB
ii  nvidia-cuda-toolkit                       5.0.35-7ubuntu1                          amd64        NVIDIA CUDA toolkit
ii  nvidia-opencl-dev:amd64                   5.0.35-7ubuntu1                          amd64        NVIDIA OpenCL development files
ii  nvidia-profiler                           5.0.35-7ubuntu1                          amd64        NVIDIA Profiler for CUDA and OpenCL
ii  nvidia-settings-319-updates               319.60-0ubuntu1                          amd64        Tool for configuring the NVIDIA graphics driver
ii  nvidia-visual-profiler                    5.0.35-7ubuntu1                          amd64        NVIDIA Visual Profiler
EDIT
$ sudo apt-get install nvidia-current
Reading package lists... Done
Building dependency tree
 nvidia-current : Depends: xorg-video-abi-11 but it is not installable or
                           xorg-video-abi-12 but it is not installable or
                           xorg-video-abi-13 but it is not installable
                  Recommends: nvidia-settings-current but it is not installable
EDIT
after making some more mess with drivers I reinstalled system (I found this option faster than playing with drivers), but still additional drivers tab is empty. Installing 'nvidia-319-updates' causes black screen after log in (with removed xorg.conf, with not removed i have extremely low resolution and also black screen)
EDIT
black screen was caused bu this bug this bug. now it works, but 'nvidia-settings' are empty (but there is no information that I am not using nvidia drivers so I guess that they are ok) nvidia-settings
Also additional drivers tab is still empty: additional settings
d21d3q
  • 166
Try installing:
It should help.
Edit:
Try:
sudo apt-get remove --purge nvidia-319-updates
sudo apt-get remove --purge nvidia-settings-319-updates
sudo apt-add-repository ppa:xorg-edgers/ppa
sudo apt-get update
sudo apt-get install nvidia-331
and reboot
Frost
  • 157
