I'm new to Ubuntu (12.04.3). I'm trying to install handbrake and I've tried about 6 different ways non seem to work, so I'm now asking for help.
Step 1 sudo add-apt-repository ppa:stebbins/handbrake-releases
$ sudo add-apt-repository ppa:stebbins/handbrake-releases
Traceback (most recent call last):
File "/usr/bin/add-apt-repository", line 128, in <module>
ppa_info = get_ppa_info_from_lp(user, ppa_name)
File "/usr/lib/python2.7/dist-packages/softwareproperties/ppa.py", line 84, in get_ppa_info_from_lp
curl.perform()
pycurl.error: (35, 'gnutls_handshake() failed: A TLS packet with unexpected length was received.')
I get and error what does the error mean and how do I fix it?
In file /etc/apt/sources.list I have this
##ppa:stebbins/handbrake-releases
deb http://ppa.launchpad.net/stebbins/handbrake-releases/ubuntu quantal main
deb-src http://ppa.launchpad.net/stebbins/handbrake-releases/ubuntu quantal main
If I ignore the error and continue.
Step 2 sudo apt-get update
I get.
W: Failed to fetch http://ppa.launchpad.net/stebbins/handbrake-releases/ubuntu/dists/oneiric/Release Unable to find expected entry 'deb-src/binary-i386/Packages' in Release file (Wrong sources.list entry or malformed file)
E: Some index files failed to download. They have been ignored, or old ones used instead.
Again if I ignore the message
and continue.
Step 3 sudo apt-get install handbrake
I get.
Package handbrake is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
W: Duplicate sources.list entry http://ppa.launchpad.net/stebbins/handbrake-releases/ubuntu/ oneiric/main i386 Packages (/var/lib/apt/lists/ppa.launchpad.net_stebbins_handbrake-releases_ubuntu_dists_oneiric_main_binary-i386_Packages)
W: You may want to run apt-get update to correct these problems
E: Package 'handbrake' has no installation candidate
If I use sudo apt-get install handbrake-gtk
I get this.
The following packages have unmet dependencies.
handbrake-gtk : Depends: libgstreamer-plugins-base1.0-0 (>= 1.0.0) but it is not installable
Depends: libgstreamer1.0-0 (>= 1.0.0) but it is not installable
Depends: gstreamer1.0-libav but it is not installable
Depends: gstreamer1.0-plugins-base but it is not installable
Depends: gstreamer1.0-plugins-good but it is not installable
Depends: gstreamer1.0-plugins-bad but it is not installable
Depends: gstreamer1.0-plugins-ugly but it is not installable
Depends: gstreamer1.0-pulseaudio but it is not installable
*Sigh nothing works :(
