I need to do partitioning to an NTFS drive that gparted said it has bad sectors. (I made a question here)
Anyways I followed its advice of using chkdsk on windows and restarted it twice but gparted still says it has bad sectors.
I thought I'd try another method and found this program (badblocks). I looked up the documentation but the program seems a bit dangerous to use on my own. (Here's the documentation)
I can't figure out the command I need to use. ... also if there's a better suggestion for a program that can help me don't hesitate. Thanks in advance :)
842Mono
  • 10,070
sudo badblocks -nvs /dev/sdX and replace sdX with the partition you want
-nvs would make a non destructive test and would show the progress and "would give a verbose output" (which means a more explicit output)
842Mono
  • 10,070
